Started by orkney, May 31, 2014, 11:20:28 AM
0 Members and 7 Guests are viewing this topic.
Many thanks Kenny, much appreciated.
Michel
#1396
Alan, some more:
TRA1E EHAM-LGPZ
TRA1P LGKF-EHAM
TRA110E LEMG-EHAM
TRA149P EHAM-LEAL
TRA23L EHAM-LIRP
TRA425A EHAM-LIRP
TRA44M GCFV-EHAM
TRA5G EHAM-LEMG
TRA50J LGKO-EHAM
TRA562C LEPA-EHAM
TRA57N EHAM-GCRR
TRA615V LEAL-EHAM
TRA62U GCLP-EHAM
TRA627P EHAM-LEPA
TRA63Q EHAM-GCLP
TRA65G EHAM-LIPX
TRA757N EHAM-LGKR
TRA763B EHAM-LEGE
TRA865H EHAM-LGAV
TRA93A EHAM-LGZA
TRA955M EHAM-LPPT
TRA98E GCLP-EHAM
TRA5L EHAM-LIPX
TRA66L EHAM-GCTS
TRA919V EHAM-LGIR
TRA429J EHAM-GCTS
TRA729H EHAM-LEZL
TRA223W EHAM-LEMG
TRA3H LEPA-EHAM
TRA3V GCRR-EHAM
TRA96L GCLP-EHAM
TRA385 EHAM-LTAI iso EHAM-LPFR
Michel.
Many thanks again Michel.
Afternoon Alan,
Just had this one come onto 'My Flights' :
E343350
Flight ID : ABEJA20
FL : 1100 ft
Also had on :
E48418
Cessna 680 : PR-BRS c/n 680-0241 but using a flight ID of PR-BBP ?
Hi Ian,
You appear to have a figure to much in your Spanish hex.  If the E is extra, I don't have its ID.
E48418 was PR-BRS previously but was re-registered PR-BBP in August.  Looks like the Brazilian online register is still to be updated/amended as both registrations are showing with the same hex code but PR-BBP is showing ARRENDAMENTO MERCANTIL in red which means LEASE.
Cheers Alan,
Got a bit mixed up with my Brazilians and Spaniards. The first one is indeed just 343350.
X
#1401
Back in sandpit and a new Iraq Airways and a Yank (miscode?) at 400 ft most likely UAEAF chopper 2875
    51405E  IAW9004                                                  2014/10/19 10:48:45
* A62875        2014/10/19 10:14:42
X
jim_stockwell
Hi Alan
Not populating for some reason is 4D022C with no other info. In the past it has a SVW35SM flight I/D and goes bak to September 2013
Jim
Welcome home X
51405E,4L-TZS,24576/818,Boeing 747-281F,Cargo Airlines guess its on lease to Iraq Airways
A62875 decodes to N496XF which as far as I can see has never been allocated so maybe a miscoded miscode!!
Hi Jim,
4D022C LX-USM Dassault Falcon 7X C/N 167 Global Jet Luxembourg, been around since 10/2012 so why it is unpopulated I don't know,  Can only presume I deleted it by accident for some reason.
Michel
Alan,
TFL845 EHAM-LTFE iso EHRD-EHEH-LTAI
Michel.
Evening, the MILs from Friday:
  3CD065  GFD1A                                                          2014/10/17 07:55:40
   3D34D0        2014/10/17 13:47:00
   3D34D0        2014/10/17 14:54:34
* 3E82AC  GAF910                                                         2014/10/17 12:37:02
* 3E82AC  GAF910                                                         2014/10/17 14:42:20
* 3E91AE  GAF913                                                         2014/10/17 14:42:54
* 3E99EE  GAF926                                                         2014/10/17 08:09:50
* 3EA8DA        2014/10/17 09:00:32
* 3EBC66  GAF061                                                         2014/10/17 14:22:10
Saturday's MIL:
   3EBC66        2014/10/18 07:02:48
   3EBC66  GAF061                                                         2014/10/18 14:07:29
   3FF0F1  DMPMK    http://www.airport-data.com/aircraft/D-MPMK.html
   3FF242  DMVPP     https://www.flickr.com/photos/jerseyaviationimages/14556876760/?rb=1
   3FF2F7
* 3FF34E  DMHLE    http://www.planespotters.net/Aviation_Photos/photo.show?id=417753
* 3FF34E  DMHLE
* 3FF368  DMECD
Sundays unknowns:
   3D1EE1  DEJYF    http://jetphotos.net/showphotos.php?regsearch=D-EJYF
   3D34D0        2014/10/19 10:38:59
   3D46D8        2014/10/19 11:39:20
   3E66F2  DKEEK   http://www.onlinecontest.org/olc-2.0/gliding/flightinfo.html?dsId=3446417
   3E66F2  DKEEK                                                          2014/10/19 12:42:43
   3E66F2  DKEEK                                                          2014/10/19 14:34:46
   3EDB00  DKYBL     confirmed decoding error of 3EDB75
   3FF0F1  DMPMK    http://www.abpic.co.uk/search.php?q=D-MPMK&u=reg
   3FF137  DMEEU    still no luck
   3FF23D  DMYRH    Roland Aircraft Z-602 determined by picture here: http://www.flugzeugforum.de/threads/76352-Flugbetrieb-in-Zweibruecken-EDRZ-ZQW-2014/page67?p=2068579 and http://www.roland-aircraft.de/index.php/produktion
   3FF23D  DMYRH                                                          2014/10/19 13:53:55
   3FF242  DMVPP        see Saturdays
   3FF329  DMGDB       nothing more
Have a nice evening!
