Author Topic: Database Update Requests  (Read 522777 times)
Michel
Re: Database Update Requests
« Reply #1680 on: November 11, 2014, 11:09:04 AM »
Alan,
Unknown Dutchman: 485110
Michel.
« Reply #1681 on: November 11, 2014, 11:17:49 AM »
Hi Paul,
The rightful owner of hex 896390 is Piper PA-28-181 Archer II c/n 2890139.  As for the A6-DCD miscoding I have no idea if it is still the case but I have changed it to the Piper anyway.
« Reply #1682 on: November 11, 2014, 11:20:34 AM »
Michel,
485110 PH-4L7 Pipistrel Alpha Trainer c/n 654 AT 912.
paul tricker
« Reply #1683 on: November 11, 2014, 11:42:00 AM »
Cheers for the info Alan, C172 was a pure (bad) guess on my part.
Here are two more, both up in the air at the same time, over 1000ft between them....
896296                           A6-MSS     C172  Fujairah Aviation... 2014/11/11 15:27:11
Ok nothing wrong with that BUT...
A77426  A6MSS                    N58GA      BE20  Papa Alpha Aviati... 2014/11/11 15:29:30
A new A6-MSS??
I'm afraid I have no records on these small things, N58GA is current on the FAA site.
Paul
ps
A6-DCD just took off using its known miscode 866390 !!
« Reply #1684 on: November 11, 2014, 11:50:53 AM »
Paul,
I would suggest that N58GA has got the wrong flight ID tied onto it by some fluke/software error instead of being tied onto the correct frame.
CYYZGUY
« Reply #1685 on: November 11, 2014, 03:04:59 PM »
Hi Alan, I have an unknown come up
Mode-S A86087
Comes up with a flight ID of 3502, no other fields populating.
regards,
Jason
40" LED Monitor
40" LED Monitor
« Reply #1686 on: November 11, 2014, 03:32:54 PM »
Jason,
It is Shuttle Americas N639RW miscoding.  It should use A860B7 so looks like we have a technician who need to visit the opticians.
« Reply #1687 on: November 11, 2014, 04:06:29 PM »
I can confirm that the 2 photos which appeared where an aircraft didn't have any photos allocated, have been deleted from the database and should not re-appear.
« Reply #1688 on: November 11, 2014, 09:45:01 PM »
I will be returning back to Scotland first thing in the morning and will be offline until Thursday evening/Friday morning.  Andrew (Orkney) will take care of you.
