Started by orkney, May 31, 2014, 11:20:28 AM
Michel
Alan,
THY2GA LTBA-EGCC iso EDNY-LTBA
CFG9HV GCLP-EDDH
TRA207 EHAM-HEGN
Michel.
Hi Paul,
50818C decodes to UR-CDP which is now EP-ZAQ MD83 with Zagros Air.  presumably using its old hex.
paul tricker
Cheers Alan,
no idea where I got UR-VVN from then!!
Paul
I believe UR-VVN was 508124 Paul.
Afternoon Alan, unknowns from Friday:
3DA2C6  DGHWW http://jetphotos.net/viewphoto.php?id=7866296&nseq=7 / http://www.skpage.de/SKpage/SKpage_Haupt/SKpage_Aviation/2014/SKpage_bot_Bronco-D-GHWW.html
3FF129  DMAJW  http://www.sdplanes.de/Fertigflugzeug/Fotogalerie/D-MAJW/d-majw_8.html / http://forum.luftfahrtclubbraunschweig.de/07-11-2014-wochenend-und-sonnenschein-t4021.html
47C26D
4CA171
F9528F
MILs:
* 3E8FC6  GAF639                                                         2014/11/07 10:05:49
* 3E9280  GAF626                                                         2014/11/07 07:59:52
* 3E9280  GAF626                                                         2014/11/07 09:24:45
* 3F4929  GAF781                                                         2014/11/07 08:13:23
* 3F750F  GAF640                                                         2014/11/07 08:43:19
* 3F750F  GAF640                                                         2014/11/07 12:39:37
* 3F750F  GAF640                                                         2014/11/07 14:15:56
Regards Ingo
paul tricker
Nothing on the FAA site, but 319 messages over 40 mins so not spurious....
* A57FCE        2014/11/09 18:41:05
Stayed around 800ft for the duration
Paul
Unknowns from Saturday:
3C2D53
3CFA34
3D1FDA  DEKHU http://www.seqair.com/Hangar/FratiAssoc/Falco.html
3E729B  DKIPF http://www.abenteuer-segelflug.com/preise/chartervertrag/
3FF2D6  DMMSE
3FF2F4  DMRUB
471F7B
4B0031
4BCEAE
Have a nice evening!
Hi Ingo,
Apart from the ones you provided the links too, the only other one I was able to add was
47C26D,LN-YRW,F705612A,ATEC 321 Faeta
Thanks again and have a good one as well
CYYZGUY
Hi Alan, I apologize if these have been posted before, I did do a search with nothing.
2 Mode S coming up with no other info populating
ADB38F
and
C007D2
regards,
Jason
40" LED Monitor
40" LED Monitor
#1660
Evening Alan,
ISS387 : LIRN-LEMD
TRA2E : LEAL-EHEH
EVE1457 : GCRR-LEAL (Using Vueling A320 EC-LVX c/n 5673. Possibly leased ?).
MON677U : LEAL-EGCC
CYYZGUY
40" LED Monitor
40" LED Monitor
Hi Jason,
No need to apologise, better twice than not at all
ADB38F N505LR H26B ex N982LC
C007D2 CF-CYZ Navion
Also populated the route and its return.
Thanks again Ian, will look into the Vueling
jim_stockwell
Hi Alan
A couple of funnies yesterday and today in that T7-TAN and EI-FEF have phots of a Wizz wintip! I think there may have been another yesterday but I forgot to make a note of it.
Jim
