Started by orkney, May 31, 2014, 11:20:28 AM
Michel
Alan,
Some more:
KLM18U ENGM-EHAM
TFL782 LTBJ-EHAM
OHY2094 EHAM-LTBJ
TRA41L LIRN-EHAM
TRA2X LICC-EHAM
TRA1W LGKL-EHAM
TRA85A EHAM-GCRR
TRA93N EHAM-LGHI
TRA67G EHAM-LBBG
TRA79Q EHAM-LGRP
TRA215Q EHAM-LICC
TRA73J EHAM-LGIR
Michel.
Good afternoon, the unknowns from Wednesday:
* 19C867  GLP9997                                                        2014/06/11 13:28:03
   38C0FC  FJVLQ                                                          2014/06/11 15:13:24
   3C4823        2014/06/11 12:13:40
   3C48E3        2014/06/11 13:46:59
   3C658A        2014/06/11 07:54:30
   3C675E        2014/06/11 09:40:11
* 3EBB11  GAF729   EGPF-EDDK                                             2014/06/11 09:25:52
* 3EBB11  GAF729   EGPF-EDDK                                             2014/06/11 13:29:53
* 3F491F        2014/06/11 13:09:03
* 3F491F  GAF775                                                         2014/06/11 17:28:11
* 440043        2014/06/11 06:07:34
* 44073F        2014/06/11 15:13:56
* 4712D8        2014/06/11 05:26:29
   4B1624        2014/06/11 11:16:14
   4BA908        2014/06/11 11:21:44
* 508140  URCLF                                                          2014/06/11 09:56:58
Regards Ingo
Hi Ingo,
19C867  GLP9997 unknown to me
38C0FC  FJVLQ unknown to me
3C4823 unknown to me
3C48E3 unknown to me
3C658A unknown to me
3C675E doesn't decode
440043 unknown to me
44073F unknown to me
4712D8 unknown to me
4B1624 not current
4BA908 decodes to TC-JHH unknown to me
508140  URCLF should be using 508142 so either a miscode or a corrupt packet
URCLF: caused by bad packet.
diddyboy
Hi Alan
Up in Paris Orly for a few days and below are the unknowns so far:
* 381D3B  TEST1234                                                       2014/06/12 16:51:55
* 381D3B  TEST1234                                                       2014/06/12 17:37:35
* 381D3B  TEST1234                                                       2014/06/12 18:45:53
* 381D3B  TEST1234                                                       2014/06/12 19:57:17
* 381D3B  TEST1234                                                       2014/06/12 20:34:17
* 381D3B  TEST1234                                                       2014/06/12 21:51:44
* 381D3B  TEST1234                                                       2014/06/12 23:14:11
* 381D3B  TEST1234                                                       2014/06/12 23:37:10
* 381DDB  TEST1234                                                       2014/06/12 16:51:55
* 381DDB  TEST1234                                                       2014/06/12 17:37:35
* 381DDB  TEST1234                                                       2014/06/12 19:18:18
* 384CFA  FWWNX                                                          2014/06/12 16:55:27
* 38C1FC  FJUSK                                                          2014/06/12 16:53:32
* 39BE5C  27AFH                                                          2014/06/12 16:52:01
   3B9BD4  FNY5114                                                        2014/06/12 00:00:00
Neil
Hi Neil,
381DDB  unknown to me but its ID leads me to believe it is a ground transmitter
384CFA,F-WWNX,002,LH Aviation LH-10 Eclipse,LH Aviation,,LH10 a first for ICAO code in the d/b
38C1FC F-JUSK microlight unknown to me
39BE5C,27AFH,00093/52,Nando Groppo Trail
3B9BD4 unknown to me
flygfantast
4AB314 SE-LXT,  Piper PA-28 RT-201T Turbo Arrow III, c/n 28R-8231013, Borj AB (ex N84718)
Also not populating: AE1D1E c/s VVPD507 (seems to be a P3-C Orion on way to RAF Lossiemouth)
[see http://www.fightercontrol.co.uk/forum/search.php?keywords=VVPD507]
Niklas
Cable: Ecoflex-10 (10m+1m)
Thanks Niklas,
There are 3 USN P3's due at Lossiemouth today.  I am waiting on tie-ups on Scotavent.  Will post it if/when it arrives
Niklas,
Now confirmed as AE1D1E 159507 Lockheed P-3C-I Orion c/n 5625 US - Navy
diddyboy
Hi Alan
Yesterday's Batch from Orly area.
* 000BD2        2014/06/13 20:42:32
* 384D9B        2014/06/13 10:46:23
* 38BE7B  FPGMG                                                          2014/06/13 09:14:22
             Owner             Aircraft Model                       Homeport
F-PGMG, RAPP CLAUDE  JODEL D 119 D (c/n 1197)    Melun Villaroche
* 391BDC        2014/06/13 09:44:51
* 398C39  FHDBZ                                                          2014/06/13 20:54:41
* 3CE005  PAV913                                                         2014/06/13 21:13:38
* A92DF8        2014/06/13 06:42:39
Hi Neil,
000BD2 unknown miscode
384D9B,F-AZTE,9172,Douglas C-47A Dakota,Dakota Et Compagnie391BD1 unknown to me
398C39,F-HDBZ,1008,Tecnam P2008,Aero Club D'Aerosports De Paris,
3CE005 decodes to D-CMDH unknown to me
A92DF8 not allocated by FAA
Michel
#163
Alan,
TRA32F LGSA-EHAM
TRA374T LPFR-EHAM
TRA496L LIPZ-EHAM
TRA520N LGSM-EHAM
TRA626F LEPA-EHAM
TRA64H LGSR-EHAM
TRA74R LGIR-EHAM
TRA1U EHAM-LPFR
TRA2F EHAM-GMTA
TRA20V EHAM-GCTS
TRA409L EHAM-LIRN
TRA5V EHAM-LIPZ
TRA562U EHAM-LEPA
TRA63M EHAM-LGBL
TRA705X EHAM-LGMT
TFL220 LGSM-EHAM iso LTAI-EHRD
TFL203 EHAM-LGZA
Michel.
