Started by orkney, May 31, 2014, 11:20:28 AM
Thanks for the info X, I will make enquiries.
superspotter
Hello from Lagos;
Bit of a strange one (how unusual!). Hexcode A4FE3E has just landed here in Lagos. He used an abridged callsign of "5-HD" and said he was a Bell 412 which I confirmed visually. The only online confirmation I can find of that hexcode belongs to an R-44 and the only "5-HD" I can find in 5N-BHD. DO you already have a hexcode for 5N-BHD in the Db Alan?
regards clive.
Hi Clive,
Mystery no more
A4FE3E 5N-BHD Bell 412EP c/n 36354 Pan African Airlines Nigeria (Miscode hex of N4202A).  The R44 used the US registration as well and is VH-KLY now.
Michel
Alan,
TRA1539 EHAM-LGKF
SAS7706 LEPA-EKCH
PGT6462 EGCC-LTAI
Michel.
X
Never above 1800ft
* A531B5        2014/06/21 13:52:37
* A531B5        2014/06/21 17:26:51
* A531B5        2014/06/21 19:01:05
X
X
#260
Two more from MOW
* 406137        2014/06/21 17:26:13
* 44CC2D        2014/06/21 15:02:36
X
CYYZGUY
#261
CCA818
No Route
Flightaware showing KIAD-ZBAA
I am finally back online with a permanent and improved antenna install!  Will be posting some pics shortly!
regards,
Jason
40" LED Monitor
40" LED Monitor
X
A531B5,RA-01890,54051,Bell 407,(Miscode hex of N4338B)
406137,RA-01905,22092,AgustaWestland AW109S Grand,(Miscode hex of G-NEBO)
44CC2D decodes to OO-SAM now RA-***** c/n 53752 B407
superspotter
Morning Alan;
There seems to have been a c**k up somewhere along the way!
Back on 22nd February this year I posted a message here that hexcode 06401E was 5N-BDK an EC-155. However every day this visit, everytime BDK calls up on the radio, BDL appears on Airnav with this hexcode! I have trawled through my posts to this list and I have never mentioned BDL. Will you amend 06401E back to BDK? I am sure you had it as BDK at one point?
regards clive
#266
Thanks Clive, probably me that c**ked it up in the first place, the c/n is correct and the K and L keys are next to each other so putting 2+2 together etc!!
5N-BDL c/n 6610 and 5N-BDM are also EC55's with Bristows but I don't have them in the d/b yet.
superspotter
You need to stay off the Shandy! :)
Unless they are based elsewhere, I have never had sight or sound of those two.
regards clive.
A wee bit stronger than shandy Clive.  My d/b details they are based in Escravos wherever that is.
X
#269
Saw new reg EI-RUW B763 Transaero c/n 30107 about two hours ago at DME and my unknown Transaero from yesterday has just departed DME, so not EI-RUX as I thought but is imminent.
4CAB5F  TSO9177                                                        2014/06/22 17:51:26
X
