Started by orkney, May 31, 2014, 11:20:28 AM
Thanks again Michel.  406A26 is not allocated.
flygfantast
Not populating:
3D0DFE D-EDNY, Grumman American AA-5B Tiger, c/n AA5B-1096
Niklas
Cable: Ecoflex-10 (10m+1m)
Afternoon, unknowns from Monday:
   02A1AA        2014/06/30 19:47:14
* 3C1295  BER644L  EDDT-EDDL    bad packet
   3C6620  DLH8FL   EDDH-EDDF      bad packet
* 3F4C2D  GAF120                                                         2014/06/30 07:39:11
* 3F8EDE  JUSTIS                                                         2014/06/30 13:17:51
* 3F8EDE  JUSTIS                                                         2014/06/30 14:12:15
* 3F904A        2014/06/30 09:59:37
   40066E        2014/06/30 22:07:46
* 400FF6  TOM3FG   EGNT-LBBG             bad packet
   401080        2014/06/30 16:07:41
   484184        2014/06/30 04:52:56
* 4AC93E        2014/06/30 06:34:47
* A142BA        2014/06/30 07:44:55
* A144BD        2014/06/30 09:27:16
Regards Ingo
Aerotower
Aircraft(A320)
Airbus A320-214
Registration(4951D8)
CS-TNX
TAP Portugal
Thanks,
Manuel
Hi Ingo,
02A1AA unknown to me
40066E not current
401080 unknown miscode
484184 not current
4AC93E unknown to me
A142BA not assigned
A144BD not assigned
flygfantast
4AB521 SE-MIA, Cessna 172S Skyhawk, c/n 172S10633, Västerås Flygklubb
4AD706 SE-UXF, Schempp-Hirth Duo Discus T, c/n 252. Hans Folkesson AB
Niklas
Michel
#354
Alan,
PGT5265 LTAI-EHAM iso EDDW-LTAI
PGT5565 LTAI-EHAM iso LTAI-EDDL
PGT5297 LTBJ-EHAM iso LTAI-EDDS
PGT5465 LTAI-EHAM iso LTFJ-LTCG
SWR72U LSZH-EHAM
PRI604 LPPD-ESSP iso LPPD-ESTA
TRA96V LGRP-EHAM
TRA42M LGIR-EHAM
TFL767 EHAM-LTAI
TRA222 LGMT-EHAM iso LGHI-LGTS-EHAM
VLG6295 EHAM-LIRF iso LFPO-LIRF
Michel.
Afternoon, unknowns from Tuesday:
* 343688        2014/07/01 14:39:11
   34429C        2014/07/01 16:19:11
* 39B5D1        2014/07/01 13:48:32
* 39B5D5  FHNOV                                                          2014/07/01 13:37:20
   3C6649        2014/07/01 06:32:28
* 3C6DDF        2014/07/01 17:16:14
* 3CCEB7        2014/07/01 21:44:49
* 3CED60        2014/07/01 15:57:06
   3D1B02        2014/07/01 10:17:15
   3E7281        2014/07/01 08:14:25
* 3E87D2        2014/07/01 09:29:36
* 3E8965        2014/07/01 08:17:35
* 3E8965  RAPTOR                                                         2014/07/01 13:10:55
* 3E8965  RAPTOR                                                         2014/07/01 14:41:52
* 3E99C9  GAF941                                                         2014/07/01 09:06:19
* 3E99C9  GAF941                                                         2014/07/01 10:30:42
* 3EA88B  GAF082                                                         2014/07/01 05:56:26
* 3EA88B  GAF082                                                         2014/07/01 09:41:02
* 3ECA41  DKROB                                                          2014/07/01 13:34:49
* 3F49A9        2014/07/01 09:03:38
* 3F49A9  BURST                                                          2014/07/01 09:57:18
* 3F49A9        2014/07/01 13:09:27
* 3F49A9  BURST                                                          2014/07/01 13:57:10
* 3F51CF  GAF283                                                         2014/07/01 14:59:07
* 3F7055        2014/07/01 08:28:51
* 3F7055        2014/07/01 09:22:08
* 3F7055        2014/07/01 13:28:04
* 3F8B1A        2014/07/01 11:51:49
* 3F8B1A        2014/07/01 12:53:56
* 3FF282  DMFLL                                                          2014/07/01 10:22:08
   3FF325  DMYSC                                                          2014/07/01 16:36:15
* 45E429  OYYAI                                                          2014/07/01 20:40:30
* 489363        2014/07/01 06:26:38
* 4BCEB1  SXS6ED   LTBJ-EHAM                                             2014/07/01 16:07:33
* FFE021        2014/07/01 05:16:54
Regards Ingo
Hi Ingo,
343688 doesn't decode
34429C doesn't decode
39B5D1 decodes to F-HNOR, not on French online register
39B5D5 F-HNOV not on  French online register
3C6649 not current
3C6DDF doesn't decode
3CCEB7 unknown to me
3CED60 unknown to me
3D1B02 decodes to D-EIMC, not current
3ECA41 D-KROB unknown to me
3FF282 D-MFLL unknown to me
3FF325 D-MYSC unknown to me
45E429,OY-YAI,879,Aerospatiale ATR 72-212A,Nordic Aviation Contractor
489363 unknown to me
4BCEB1 decodes to TC-SUQ, not assigned, bad packet??
FFE021 unknown miscode
CYYZGUY
Hi Alan, interesting aircraft here...showing up as a miscode..
N240RT (Mode-S) 300000
The aircraft type is "BROU"
Bremont Watch Company
Miscode allocated 385C4F
Is there anything you can do with this infomation?
regards,
Jason
40" LED Monitor
40" LED Monitor
#358
I am at a loss with the info you have passed Jason as you have detailed two very different aircraft.
N240RT is a Cessna 421B Golden Eagle hex A23188 of D M Air Services and is in the d/b correctly.
385C4F,F-BXCP Max Holste 1521M Broussard c/n 149 Bremont Watch Company and wasn't in the database using its correct hex and operates out of White Waltham in England.  Cant see why it would be in Canada.
Just noted F-BXCP has been noted using hex 300000 so it would appear that N240RT is also using it as a miscode as well.  I will therefore amend the miscode to being used by more than one aircraft.
CYYZGUY
Hi Alan, another unknown for me today...
Mode-S 4850DA
Flight ID PHRLG no other info populating.  I cannot find anything on it..
regards,
Jason
40" LED Monitor
40" LED Monitor
