Record number of flights in MyLog?
Started by RodBearden, July 03, 2014, 12:46:28 AM
My MyLog has been running since August 2008 (yes, it does take quite a time to load).
I've just noticed that one aircraft, Jet2 B733 G-CELY has got 6707 entries - an average of over three flights a day logged over nearly six years.
Is this a record?
While I'm at it (and I'll probably lose this one) I've got 27,788 aircraft in MyLog (for all time). Can anyone beat that?
CYYZGUY
#1
Rod, that is quite impressive.  I am no where near that as ADS-B is still only growing in North America,
I must admit, I have noticed over the last few years, ADS-B is starting to become much more common here...
regards,
Jason
40" LED Monitor
40" LED Monitor
Hi Rod I've  set up new 24/7 PC January 2013
since then D-AGWS A319 of Germanwings has performed about 4000 flights. If it stays that busy I'll beat the 6707 flights after six years.
Number of records: 28767 (including the decoding errors)
Col
Unfortunately I deleted all my old data back in December so I don't have a good count of totals by aircraft - most of the BA A320's I seem to have logged about 600-700 times in the last 6 months.
My total aircraft logged comes to 42,751 in the period since December 2009 when I set up my RB. It helps that I have been able to take it to Japan, Australia and the US a few times!
Colin
Wokingham, Berkshire
