Started by orkney, November 12, 2014, 11:19:39 AM
orkney
Hello
This is a new Database Update Requests thread since the old one is now large and unwieldy so has been locked.
Thank you in advance for your requests.
Andrew
orkney
Hello
Do you know what  the type of aircraft in the picture?
Thank you
Andrew
M
orkney
Hello Falcon and M
Thank you both for that, it is in now.
Andrew
Michel
Andrew,
CFG1KM LPMA-EDDH
SQC7347 EHAM-VABB-WSSS
THY2GA LTBA-EGCC
Michel.
orkney
Hello Michel
Many thanks for that three. They are in now.
Andrew
flygfantast
Andrew/Alan
The 2 "mystery" Ukraine aircraft visible on radar today again after take-off from ESOE airport and heading for Minsk-area:
5082FA using URGA574 when talking to tower/control.
508306 using URGA576 when talking to tower/control.
URGA = Air Urga (3N, URG).
I suspect one of them is UR-ESA (ex N449XJ, HS-GBF) Saab 340B c/n 340B-449.
Niklas
Cable: Ecoflex-10 (10m+1m)
orkney
Hello Niklas
Sorry but I can't find any informations on these two yet. I will look again tomorrow.
Thank you
Andrew
CYYZGUY
40" LED Monitor
40" LED Monitor
Some unknowns from the past week to test the new SWc release:
Friday:
3E9EAB  GAF608
3FB405
44D105
* 75839F  PAL5004 A321-231SL, Philippines Airlines, D-AVXN, RP-C9916 (MSN 6363)
* 8880D5  HVN8612 A321-231, Vietnam Airlines, D-AVXI, VN-A612 (MSN 6344)
AE1700
unknowns from thursday:
* 3B76A1        2014/11/13 14:35:18
   3E8F82  GAF729   EGPF-EDDK                                             2014/11/13 12:01:55
   3E8F82  GAF729   EGPF-EDDK                                             2014/11/13 13:37:37
* 3E9661  GAF483                                                         2014/11/13 07:25:08
* 3E9661  GAF483                                                         2014/11/13 08:40:11
   3E9EAB  TA61                                                           2014/11/13 09:09:47
   3E9EAB  TA61                                                           2014/11/13 11:14:48
* 3F882C  GATOR2                                                         2014/11/13 14:04:28
* 3FA389  GATOR1                                                         2014/11/13 13:05:46
* 3FA732  SPEAR                                                          2014/11/13 10:19:47
   3FA8F7  SMASH2                                                         2014/11/13 08:30:18
   3FA8F7  PACK1                                                          2014/11/13 13:36:35
* 406B89        2014/11/13 20:37:16
* 45D066        2014/11/13 14:57:02
Wednesday:
* 3E8BAE        2014/11/12 09:31:33
   3E9EAB  TA64                                                           2014/11/12 11:03:37
   3FA8F7  SMASH2                                                         2014/11/12 08:17:04
   3FA8F7  SHOCK2                                                         2014/11/12 13:19:56
* 405630        2014/11/12 18:39:58
* 44007E        2014/11/12 10:33:06
* 4CA4FC        2014/11/12 09:41:55
* A9432D        2014/11/12 11:31:31
* AE16E4        2014/11/12 15:05:39
Tuesday:
* 06A143  QTR3380 their second A388 I guess
   3E9EAB  GAF634                                                         2014/11/11 11:15:29
   3F414D  GAF639                                                         2014/11/11 10:26:33
   3F414D  GAF639                                                         2014/11/11 12:08:39
   3F414D  GAF639                                                         2014/11/11 14:02:38
* 3FA8F7  VADER2                                                         2014/11/11 08:00:40
* 3FA8F7  SHOCK2                                                         2014/11/11 13:25:50
* 44A246        2014/11/11 20:37:19
* 45C941        2014/11/11 20:16:58
* 8D1730        2014/11/11 06:07:11
* B800CE        2014/11/11 10:02:35
Monday:
* 3986F4        2014/11/10 06:27:46
* 3C66AB        2014/11/10 20:11:57
* 3E3918        2014/11/10 11:50:35
* 3E8F82  GAF709                                                         2014/11/10 16:56:41
* 3E8F82  GAF709                                                         2014/11/10 19:23:37
* 3E9EAB  GAF626                                                         2014/11/10 09:39:06
* 3E9EAB  GAF626                                                         2014/11/10 12:00:10
* 3F414D  GAF639                                                         2014/11/10 09:44:48
* 3F414D  GAF639                                                         2014/11/10 11:40:52
* 3F414D  GAF639                                                         2014/11/10 12:57:05
* 3F70AF  GAF161                                                         2014/11/10 08:52:52
* 3F8BCD  LM01                                                           2014/11/10 09:07:15
* 3FBF43        2014/11/10 09:35:42
* 3FBF43  BU12T                                                          2014/11/10 10:18:39
* 3FBF43  KNIGHT2                                                        2014/11/10 14:25:00
* 42409D        2014/11/10 23:45:05
* 4AD555        2014/11/10 07:55:58
* B803CE        2014/11/10 12:11:39
* EA03C9        2014/11/10 12:49:22
