Started by orkney, November 12, 2014, 11:19:39 AM
Many thanks Michel, your time and effort is appreciated.
Evening Alan,
Thanks for tracking down the DLH53C I couldn't find it anywhere including the LEMG departures board. Regarding the Evelops, I had logged the original routings for them on the 26th March i.e Winter timetable and logged again today Summer timetable with the same flight ID´s but different routings so not sure if it is a genuine change of routes from Winter to Summer or if it is repositioning flight ID's. I will see what the coming days turn up if they are logged again.
Kenny
Three new from yesterday.
* 880003        2015/04/01 10:39:38
* 882045        2015/04/01 14:11:10
* 8CC000        2015/04/01 11:18:41
Kenny
ANRB 3km north of VTBD
CYYZGUY
40" LED Monitor
40" LED Monitor
Morning, one early route:
CFG8FK D-AICD new EDDV-LGRP (DE4676)
Morning Alan, unknowns from Wednesday:
2151A2  V   R no country allocation
* 3A77DA        2015/04/01 11:17:47
* 3A77DA        2015/04/01 16:59:52
* 3A77DA        2015/04/01 18:43:47
* 3A77DA        2015/04/01 19:51:12
* 3A77DA  FAF9051                                                        2015/04/01 20:41:06
--> FAF Force Aerienne Francaise (French Air Force)
German Airforce:
* 3E87C9  GAF320                                                         2015/04/01 07:52:31
* 3F62B4        2015/04/01 13:32:17
* 3F6985  GAF062                                                         2015/04/01 08:52:57
* 43EA42  MCSMS                                                          2015/04/01 07:16:45
* 43EA42        2015/04/01 08:48:43
* 43EA42  MCSMS                                                          2015/04/01 11:17:49
posted by falcon_nl yesterday, obviously added after I ceceived it
4407CD  IJM489 IJM: International Jet Management
4BCEBD nothing more
5110BE nothing more
Back to the routes...
Regards Ingo
CFG9LD D-AIAD new EDDV-LEPA (DE4534)
M
WZZ1003   EFTU   EPGD
FCM5674   EFKI   EFHK
FIN59P   EFHK   LDDU
UAL981   OBBI   KIAD   via OKBK
After DB Update
SAS1672 EDDV-EKCH (SK1672) has disappeared from db.
THY6305 TC-LER new LTBA-EHBK (TK6305)
WZZ5UT HA-LWP new EYVI-LEBL (W68063)
DLH5KW D-AILW now EDDT-EDDM (LH2053)
CFG1HE D-ABOF now EDDH-LPMA (DE4506)
DLH3YX D-AISZ now EDDH-EDDF (LH3)
GWI73U D-AIQS now EDDK-EDDT (4U12)
DLH4M D-AIZE now EDDH-EDDM (LH2083)
AFR161F F-GRHB new EDDH-LFPG (AF1611)
GWI62K D-AGWT new EDDH-ESSA (4U7214)
DLH2AC D-AECC new EPGD-EDDF (LH1379)
GWI31W D-ACNU new EDDH-EDSB (4U7234) re-check after landing...
WZZ8ES HA-LPU new LRCL-EDLW (W63361)
WZZ9PW HA-LYL new EPWR-EGGW (W61801)
WZZ2LP HA-LPN new EPWA-EGGW (W61301)
THY3038 TC-JRI new LTCG-EDDL (TK3038)
GWI94A D-ACNK EDDL-ESSA (4U9216)
GWI5W D-ACNR EDDL-EPWA (4U9724)
DLH6TP D-AILC now EDDM-EDDL (LH2002)
All EDDL flights confirmed via DUS timetables (as EDDF they kindly state the airframes reg if you go to flight details)
GWI31W D-ACNU new EDDH-EDSB (4U7234) confirmed!
GWI3J D-AIQP new EDDT-LFPG (4U8406)
DLH5YA D-AIZA now EDDT-EDDM (LH2055)
DLH8WT D-AIZN now EPWA-EDDF (LH1353)
DLH3PJ D-AIRA now EDDH-EDDM (LH2060)
DLH5JT D-AIPM now ENGM-EDDF (LH865)
