Started by orkney, November 12, 2014, 11:19:39 AM
Hi Keith,  I didn't put it in the d/b as it is a civil hex for a mil tactical code which is used then discarded.  If it is received again I will add it in.
Thanks Ingo,
Added it in this morning
Northern Watch
Hi Alan
Thanks, that makes sense to me. I will keep an eye out just in case.
Keith
X
* A4AD15        2014/12/05 15:33:21
* A4AD15        2014/12/05 17:28:18
Decodes to N400ER which is/was Piper PA-42-1000
X
Thanks X,
It is N400ER ex LN-ACV
X
Royal Jordanian according to c/s but not by its Spanish hex!
* 340734  RJA612   OJAI-OMDB                                             2014/12/07 01:21:00
X
X
Post from Volker on mode_s shows that this is JY-AYT departing AUH.  It arrived using the correct 740347 so one box miscode>
M
FCM5PG   LOWW   EFHK
XMS001   EGKK   EFRO
XMS002   EFRO   EGKK
NWS3319   ULLI   MDPC
NWS3515   UUEE   MMUN
NWS3516   MMUN   UUEE
NWS3517   UUEE   MDPC
NWS3518   MDPC   UUEE
TSO553   UUWW   MDPC
TSO554   MDPC   UUWW
ABW501   UUEE   KDFW   via KORD
Morning, the only unknown from Saturday:
3C646F nothing more
Have a nice Sunday!
Morning Ingo,
3C646F decodes to D-AICO unknown to me
interesting, I got this hex on two different Radarboxes with about 100 messages on each device. Maybe a miscoded airframe or something else.
Could be Ingo, maybe its new and just unknown to me.  I would normally expect a flight ID to show.
The REG indicating that it should be some kind  of commercial aircraft. And in that case I would expect a flight id too. But if it's a miscoded small airframe a flight isn't necessarily received, especially if the airframe is at the edge of my reception range.
With low message count and airframe received on only one box decoding error or a scrambled packet would be my first guess. But in this case I got it at the same time on two boxes with quite high message count. Therefore I thought that it might be something else.
As usual in that kind of cases: time will tell...
