Started by orkney, November 12, 2014, 11:19:39 AM
D-ASXP SXD4648 ?-EDDK
D-ACNV GWI21N (4U7028) EDDH - EDDC
D-ACNW GWI12J EDDL - POZ
D-ACNR GWI97V (4U7062) EDDH - EDDL
D-ACNQ GWI27J (4U9042) EDDL - EDDT
D-ACNL GWI60X (4U7234) EDDH - EDSB
D-ACNH GWI24W (4U9220) EDDL - ESGG
#556
about the GMI and the two HAY flights:
I got the flight id from my daily Log Mail. The route information is from FR24 and Libhomeradar. Checking airport time tables is impossible with current web speed. Collecting the route infos were already a very hard job.
We have to wait if these flight id's show up again and if the departure arrival airport is the same as the first time.
Many thanks Ingo, much appreciated
Michel
QuoteCSN455   ZGGG   EHAM
CSN457   ZGGG   EHAM
For both, this should be ZGGG-ZUCK-EHAM
Michel.
Thanks for the clarification Michel
Kenny
New from yesterday.
* 38CF7B  EC155                                                          2014/12/16 14:51:45
Kenny
ANRB 3km north of VTBD
X
#561
Spicejet not populating...this is VT-SZH which has been around for a while
   8007E2  SEJ013   VABB-OMDB                                             2014/12/17 01:50:44
   8007E2  SEJ014   OMDB-VABB                                             2014/12/17 03:49:46
X
M
* 507C26, miscoded aircraft still using its old Uzbekistanian hex:
507C26 IL62 RA-86576 Ilyushin IL-62MGr cn:4546257 KAPO Avia (allocated 155230)
I cant find any details on that code Kenny.  I suspect it is a Eurocopter test code.
Hi X
VT-SZH is c/n 41261/4573 which is showing on the FAA list as assigned as import as N868TM so I changed its details.  It therefore looks like it is still with Spicejet but I wonder for how much longer given their flight have been grounded today http://www.bbc.co.uk/news/world-asia-india-30510278
Thanks M, miscode added to d/b
Good afternoon Alan, the unknowns from Tuesday:
0800E0 nothing more
3C485F nothing more
3CE067  MHV777 MHV: MHS aviation
400C45 was G-EZID nothing about a new one
521F96 no country allocation, therfore a bad packet received or a miscoded airframe
8003C8 nothing more
MILs:
* 3E81E1        2014/12/16 08:55:17
* 3EA184  PANTER2                                                        2014/12/16 09:14:24
* 3EBBF2  SPOOK                                                          2014/12/16 13:11:18
* 3EBD73  JUSTIS1                                                        2014/12/16 13:14:22
* 3F6491  BU24T                                                          2014/12/16 13:46:45
* 3F6491  BU24T                                                          2014/12/16 15:12:29
* 3F6C71  ATTACK                                                         2014/12/16 11:59:55
Regards Ingo
Afternoon Ingo,
The mil added
The only other with info is below
3CE067  MHV777 decodes to D-CMHB and was noted climbing out of Switzerland possibly Berne yesterday  The previous holder of the registration is now HB-AEV D328 with Skywork but it is still showing on the Swiss online register.  Miscoding old hex and ID??
D-AHFI TUI996 ??? - SAW
D-AHFP TUI997 SNN - SAW
D-AIAA CFG8PH (DE2489) GCFV - EDDV
D-ASXK SXD3931 EDDV - GMMX
D-ASXK SXD3943 EDDH - GMMX
D-ASXK SXD3930 GMMX - EDDV
D-ATUH TUI8238 (X38238) EDDM - EDDV (might be a positioning flight)
D-ATUH TUI8239 (X38239) EDDV - EDDM (same as 8238)
Regards Ingo
I'll put 3CE067 on my monitor list.
