Started by orkney, November 12, 2014, 11:19:39 AM
Xon
Afternoon Alan,
Further to EC-MEC AT75 c/n 595. Thanks for the confirmation. The aircraft is owned by Swiftair but is currently operating scheduled services for Air Europa sometimes with a Swiftair flight ID and sometimes using an Air Europa flight ID.
My pleasure Ingo,  as its plotting I hope they don't eventually go Tactical.
Yes indeed. Hopefully it'll stay like one of the A310, which are almost always  plotting.
Hi Alan, here are the unknowns from Thursday:
3C65C9 nothing more
3C70C6 nothing more
3CC12D nothing more
3E4B2A nothing more
424763  WGT54H must be this one: http://forum.luftfahrtclubbraunschweig.de/18-12-14-neue-vw-falcon-7x-vp-cuh-t4078.html
47A723 nothing more
4C12A2 nothing more
AB1EA8 two times with a separation of 1hour. Seems like it landed in EDDV, fueled up and moved on its way...
ABDA79 decodes N863F currently not assigned by FAA
F1303F no country allocation, therefore a corrupted packed received would be my guess
MILs:
* 3E95DD  GAF456                                                         2014/12/18 08:00:23
* 3E95DD  GAF456                                                         2014/12/18 15:39:36
* 3E9905  GAF910                                                         2014/12/18 11:21:36
* 3E9D0F        2014/12/18 08:32:09
* 3F4956        2014/12/18 09:03:40
* 3F65DF  GAF726                                                         2014/12/18 08:39:23
* 3F7B8D  GAF163                                                         2014/12/18 17:00:45
* 3F7B8D  GAF163                                                         2014/12/18 19:49:02
Regards Ingo
D-ABLB GMI357 (ST357) EGCC- EDDM
D-ABQP BER776P (EDDN - EDDL) unconfirmed
D-ACNM GWI12J (4U9734) EDDL-EPPO (Confirmed via DUS Timetable / http://www.dus.com/de-de/fl%C3%BCge/flugdetail?flight=962818)
D-ACNN GWI8093 (4U8093) EDJA - EDDT
D-ACNN GWI91E (4U7091) EDJA - EDDH
D-ACNN GWI32Y (4U8092) EDDT - EDJA
D-AHXE  BER870 EDDT - EDDV (since then [20:30UTC] no further flight of this airframe.)
D-AKNP GWI2BT (4U2000) EDDS - EDDT
D-ASTT GMI805 LFBO - EDDH
D-ASXK SXD1029 (XG1029) EDDV - EDDB
Out of Toulouse as WZZ701 is 471F86,HA-LYK,6394,Airbus A320-232,Wizz Air,
X
Unknown Brazilian
* E4913A  PRLCY                                                          2014/12/19 20:24:30
X
#610
Hi Ingo,
Mils  added
AB1EA8 decodes to N81522 not assigned. 4 previous users of the registration that I can find nd no reason to think that any of them would be in Germany
1 Bell 407 now in Panama
2 C208 in South Africa
3 SR20 TC-CHK
4 AC50 N999DA
424763  WGT54H VP-CUH would be a good call but nothing to add to the others.  Many thanks and also for the route info
Have a good weekend
X
E4913A PR-LCY Embraer 135BJ c/n 14501202 on delivery 18-19dec14 SJK-REC-CMN-SHJ, to be VT-KJG FOR Kalyan Jewellers
Flieger_NDS
Quote from: neroon79 link=topic=8219.msg108963#msg108963
Confirmed, I took the photos and had it in my log. But a c/n would be highly appreciated, I have no clue.
3CCE80 D-CFMU got reassigned, most likely to B350 FL-906, but I cannot confirm. The aircraft came this afternoon ferry from Wichita to EDVE where it gets special mission conversion. The Reg gets reused by Aerodata for the conversion in Germany. Anyone with any reliable information?
I cant find anything on either yet, other than your photo.   D-CFMU isn't FL-906 as it recently became N715A with Aramco earlier in the month.
Flieger_NDS
Yes, I also had my doubts about D-CFMU. I need to get a visual but it was dark already when it landed. I hope it didn't get towed in the hangar by monday.
The previous D-CFMU became YU-BTD, so it must be a new one.
