Started by orkney, November 12, 2014, 11:19:39 AM
Another CLX:
CLX866 (CV866) ELLX - EDDV
Strange one?? but I saw it myself, thanks again
This was the second time, that this relation was flown with this flight id.
It's not that uncommon, that CLX flights are landing in EDDV. I would say roughly two or three landings per month.
Hi Alan, can you check this one please:
DLH7MM (LH2102) is not EDDM-EHRD, but is EDDM - EDDV
it is still showing the false route info.
Ingo, it is showing as EDDM-EDDV in the d/b as per attached.  What is it showing in your Navdata and what date does it show.
In my navdata it is still EDDM EHRD with date 20141012174226 Autoupdate is set to Y(ES).
I'll have deleted the entry on one of my two systems. Tomorrow LH2102 will take place again. Then we'll see, if it's populating correct. If yes I'll delete it on the second system too.
By the way: is it correct, that fnumber_commercial reads DLH2102 shouldn't it read LH2102. I thought that the commercial flight number would be the IATA flight number and thats LH2102.
Its possible its not auto updating.  I just update everything each time I update the Navdata which is every day so don't really make much use of auto update but I know this is not possible for yourself.
The system uses ICAO for the f/n commercial and automatically changes it to the IATA for display
#728
Thanks for the info about the system.
If you have time you should look up AFL2305 VQ-BCN on the network. It seems, that the route information is not correct.
Update: route shall read EDDF - UUEE
Thanks Ingo, corrected it.  BTW I have passed DLH7MM back into the d/b so ch will be todays date.
some more route updates:
D-ALEB BCS6802 (QY6802) EDDP - LOWL
D-ALEC BCS917 (QY917) EDDP - EPKT - UKBB but sometimes EDDP - UKBB directly your decision if you add it or not
D-ALEG BCS6793 (QY6793) EDDP - EDDS
D-ALEG BCS898P (-) EDDS-EDDP I guess this was an "empty" positioning flight back. Ussually it goes back with FID BCS4298 at about 21:00UTC of the same day. BCS898P went back at 6:00 UTC of the same day (Dec 24th). BCS898P shouldn't be entered, but BCS4298 should -if it's not already in.
D-ALEK BCS6001 (QY6001) EDDP - LIMC
D-ALEK BCS800 (QY800) LIMC - EDDP (this time, three days earlier it was EDDP - EGNX, better not to be entered)
D-ASXA SXD1034 (XG1034) EDDV - EDDL (this might be a one time flight. Was not in EDDL arrival table, better not to be added I guess)
G-BIKC BCS6824 (QY6824) EDDP - LFML
G-BIKG BCS6404 (QY6404) EDDP - LIME
G-BIKK BCS6701 (QY6701) EDDP - EDDK
G-BIKK BCS4811 (QA4811) EDDK - EDDP
G-BIKO BCS6681 (QY6681) EDDP -EDDK
G-BIKZ BCS6170 (QY6170) EDDP - LIPZ
G-BMRA BCS7396 (QY7396) LIME - EDDP
G-BMRA BCS6078 (QY6078) EDDP - EDDF
G-BMRB BCS808P (-) LFSB - EDDP (might be a positioning flight)
G-BMRC BCS2689 (QY2689) EGGW - EDDP
G-BMRD BCS6707 (QY6707) EDDP - EDDM
G-BMRD BCS819P (-) EDDM-EDDP @ about 6:30UTC (the route for BCS819P in the db is LFMP - EGNX, but this route should be deleted as BCS???P FIDs seeming to be positioning flights) Regular flight back (EDDM -EDDP) is BCS4107 (QY4107) operating at about 21:45UTC
G-BMRE BCS6915 (QY6915) EDDP - LSGG
G-BMRF BCS2689 (QY2689) EGGW - EDDP
LZ-CGQ BCS6887 (QY6887) EDDP - LIMC
LZ-CGR BCS6059 (QY6059) EDDP - LEBB
LZ-CGR BCS8060 (QY8060) LEBB - EDDP
LZ-CGS BCS6203 (QY6203) EDDP - EPGD
PH-HSC TRA12V (HV6868) LGAV - EHAM
PH-KZS KLM13S (KL1767) EHAM - EDDF
PH-XRC TRA83Z (HV6833) EHRD - LOWI
PH-XRV TRA9G (HV5961) EHEH - EKCH
PH-XRV TRA962K (HV5962) EKCH - EHEH
TC-AIP PGT31PP (-) ???? - EDDL
Michel
Morning, continuing list...
B-2095 CAO1008 (CA1008) EHAM - ZSPD
CS-TNK TAP2926 (TP2926) LPPT - ENGM - ESSA - LPPT (unfortunately this doesn't fit in our system. But this "round-route" is sceduled for Janurary the 1st of 2015 again)
D-AHFR TUI196 (X3196) EDDV - EDDM (this one might be a positioning flight)
D-ASXP SXD4697 (XG4697) EDDL - HELX
D-ASXP SXD4696 (XG4696) HELX - EDDL (not in arrival table, therefore it could be an empty flight back)
OK-SWW TVS1TU (QS1034) LKPR - LFPG
OK-SWW TVS2UT (QS1035) LFPG - LKPR
PH-XRC TRA37M (HV5606) LOWS - EHRD
PH-XRD TRA83Z (HV6833) EHRD - LOWI
TC-JGP THY3021 (TK3021) LTBI - EBBR
TC-JGP THY3020 (TK3020) EBBR - LTBI
TC-JNE THY6A ( - ) KORD - LTBA (usually THY6 / TK6, but on the way to KORD TK5 was diverted to BIKF, no need to enter)
db amendments:
3DDC5C  D-HDRW     EC35  Deutsche Rettungs... operator shall read DRF Luftrettung.
3C0A52  SXD17D   LTAU-EDDL       D-ASXP     B738  SunExpress Germany / operator of other SXD airframes read SunExpress Deutschland. We should remain consistent.
Have a nice Day!
PH-HZX TRA5U (HV5291) EHRD - LOWW
PH-XRC TRA292U (HV5292) EHRD - LOWW (optained from flight on Dec. 23rd)
