Started by orkney, November 12, 2014, 11:19:39 AM
0 Members and 7 Guests are viewing this topic.
Paul,
80053E VT-PPT now correctly coded after many years.
Thanks for the route notification, now corrected.
Hi Kenny
Nothing on your miscode and thanks for the route info.
Afternoon Alan,
EVE1454 : LEAL-LEAS
Also, with regard to the aircraft photos. I have emptied out my photos folder to start afresh with the new provider (?). However, it now appears to be a complete hit or miss as to whether photos download or not with the 'photo not available' script showing even against aircraft seen 10's if not 100's of times in the aircraft history. Is it the case that the new provider does not have the same comprehensive database as the old one and therefore I have to add in these unavailable photos myself ?
Hi Ian,
Thanks for the route.
I would never suggest to anyone to empty their photo folder which has taken years to build up, I certainly wouldn't.  There is a problem with the photo look up routine which I advised Airnav about yesterday and once corrected this will hopefully improve matters for you.  Whether the new providers have such a comprehensive database as the old one I cannot answer as I have no knowledge of this.
Cheers Alan,
I'll wait and see how the photo downloads pan out. As you are aware, I'm more of a 'number cruncher'
than a photo collector so it was no big deal emptying the folder and starting afresh. I would certainly agree with you that if you place importance on photos best not to empty the folder !
Afternoon Alan, the unknowns from Monday
* 3FB299 MIL
* 3FB4B6 MIL
* 3FF300  DMHLE  caused by bad packed
* 43204B nothing more
* 478349 nothing more
* 494104  NJE079C  http://www.flightradar24.com/data/airplanes/cs-phd (If you have added it, there would have bee a problem with the the populate function or / server as I've received it at 10am and ran a populate at 5pm.
* AE16E5 US MIL
MILs
* 3E853B  GAF143                                                         2014/11/17 11:35:12
* 3EB4A6  GAF715                                                         2014/11/17 12:56:26
* 3F6AE2  GAF639                                                         2014/11/17 15:55:08
* 3F8680  BARON3                                                         2014/11/17 13:24:22
* 3F8D2C  GAFE04                                                         2014/11/17 14:35:35
* 3F8D53  GAF132                                                         2014/11/17 09:28:03
   3F8E6C        2014/11/17 09:50:26
   3F8E6C  MISTY                                                          2014/11/17 14:24:45
* 3F9160        2014/11/17 13:43:24
* 3F9160  DARK                                                           2014/11/17 17:38:23
* 3F96E7  BOMBER1                                                        2014/11/17 09:41:27
* 3F9878        2014/11/17 08:21:40
* 3F9878  GAF640                                                         2014/11/17 11:37:45
* 3F9878  GAF640                                                         2014/11/17 14:40:51
* 3F9DE2  BOMBER2                                                        2014/11/17 09:49:58
Regards Ingo
Good evening Ingo,
43204B no allocation
478349 not current
494104  NJE079C CS-PHD has been in the database since delivery in early October.  I didn't have the c/n available then and have added the c/n to it tonight so I can't understand how its not already in your database.  Just checked mine and its there.
Netjets has populated now. Maybe it's related to the actual slowlyness. I'll monitor this whith the other unknowns.
The MILs from my todays list haven't populated during the first run. I've started a second.
John Racars
FN NO ND NV || REMARKS NO ND NV
New:
NVR184 GCFV EKCH
FHY584 EGKK LTBJ
Suggestion(s)
to correct:
TUI65K GVBA EDDH GVAC || i.s.o. EDDH GVAC EDDH
13 NM East of EHAM
ANRB:
Version: 3D - 5.00.072
PC: Windows 7 SP 1 - 64 bit
RadarBox24 station: EHAM4
They haven't populated during second run. I'll try tomorrow morning again.
Thanks again John.  The route data received from TUI shows that TUI65K operates HAM-BVC-SID-HAM.  Unfortunately I can only get 3 points of the route so went as per the d/b.
John Racars
Hi Alen,
Understand. But in that case it should be
HAM-HAM-(BVC or SID) if I may say so.
i.s.o.
HAM-(BVC or SID)-HAM......
Maybe I do not understand.
Does not matter any way.
Kind regards, John
13 NM East of EHAM
ANRB:
Hi John,
You are correct changed d/b to EDDH-EDDH-GVAC
Kenny
Two new..
* 385C3B  FWKVI                                                          2014/11/18 13:51:09
* 4000C3        2014/11/18 11:56:04
Kenny
ANRB 3km north of VTBD
