New Windows Software Version
Started by AirNav Development, November 13, 2014, 11:55:49 PM
Kenny
#1
Download the upgrade.  Installed and found this error when lunch
"The program can't start because adsb.dll is missing from your computer."
Reapply the upgrade ANRBUpgradeto50071.exe  and the ANRB can start again.
Still haven't tried the full install.  It shows 1 hr download.
Kenny
ANRB 3km north of VTBD
acars45
I tried it. It dies not work missing file
nortonbeak
Hi Airnav Development,
please see my posting here: http://www.airnavsystems.com/forum/index.php?topic=8218.15 and my two PMs.
Did anyone test the full install? If yes, does the problem exist there too? If not, save your time and wait until I've tested it. Full install: 300mb and quite low download speed at the moment.
Thanks Ingo.
Full Install has the same problem. ADSB.dll is missing.
Airnav is aware of the problem and will have a look into it within the next couple of hours.
acars45
Evening all downloaded full version
Does not work missing file etc
Paul
#8
Hi Paul,
airnav is informed and they told me that a new download will be available within the next few hours.
Notice:
Both versions full/update are affected with the missing adsb.dll problem.
Upgrade still doesn't work - now it's missing MSVCR120.dll :-(
Do you test these before you release them?
And it still says it's upgrading to 5.00.71
acars45
same problem does not work missing file
Hi Paul,
which file is missing? Are you shure, that you have used the new downloaded file?
Tested full install. It's working now. http://www.airnavsystems.com/download/anrb/ANRB50072Setup.exe
acars45
done full unstall this is the message
downloaded new upgrade does not open message
the program cant start because MSVCR100 DILL IS MISSING FROM YOUR COMPUTER TRY RENSTALLING THE PROGRAM TO FIXTHE PROBLEM
paul in kent
