RB stopped receiving signals
Started by Navman, April 21, 2008, 06:28:08 PM
Navman
My RB has stopped receiving signals, the blue USB LED is flashing but only an occasional flash from the white signal LED. It works ok on Network flights but when I turn off the network nothing.
I have had the unit since January 08 working well with the antenna in the attic no problems. Last Saturday I installed a new antenna on the chimney and it worked all over the weekend with excellent range using a Sandpiper antenna and Westflex cable with a short flexible cable connecting the Westflex to the RB SMA socket
Switched on today (Monday afternoon) no signals. Tried the antenna in the attic and the supplied mag mount antenna with no signals received.
Any suggestions please
Navman
Doesn't seem like a concidence that it occured after the antenna change. Could be some thunderstorms around.
Best way is to contact support and we can send you details on a RTB.
Airmad
Quote from: Navman on April 21, 2008, 06:28:08 PM
Look at Silly Plug
Navman
Airmad,
I see the quote, but no message from you :-)
Airmad
#4
Quote from: Allocator on April 22, 2008, 07:59:29 AM
Airmad,
look at centre pin on sma plug. mine sometimes pulls back. best thing to do push hard on lead the make pin move Forward. hope this helps
wheeler
I had the same problem worked ok for 2 days then nothing was going to send it back but when i unpluged it RB from an extention USB lead it all junped into life again check your connections plus dont think they like extention leads this may help
Cheers wheeler
