Database update not working....
Started by CYYZGUY, December 26, 2014, 06:11:08 PM
CYYZGUY
Hey all, 1:07PM EST here
Getting....Invalid Data Received from Server.  Update Aborted..
Cheers,
Jason
40" LED Monitor
40" LED Monitor
Confirming the problem.
Is it possible, that the problem with the route auto update is related to this problem.
The deleted route of DLH7MM does not auto-populated / auto update. Therefore it's logical, that the isn't  update on the other system either.
The server has been restarted all should now back back to normal
Ingo,
The DLH7MM issue you mention will be related to the server being offline
Flight id DLH7MM has populated with correct route info.
Auto-Update on second system didn't work.
I guess that  I need a reception after a flight timeout for auto-update to work. As this isn't the case auto update can't work.
I'll wait until tomorrow.
Yes correct Ingo, auto update needs to be picking up the signal
