Log Times
Started by Spaice, April 21, 2008, 08:24:28 PM
Spaice
Not sure if this has been mentioned before, but despite the correct time being set in file/preferences/set time & date, the logs are recorded one hour behind.  Is there a way to change this.  Day light saving has been applied.
Aviation uses UTC time which does not change regardless of day light saving. Hence the logs at the moment in UK for instance will show one hour behind as UK is on Summer Time which is UTC+1.
Spaice
Thanks very much for responding so quickly.  Will this be something that the user can select in subsequent release of RB?
dchainey
Ah, that explains why California is showing as +7 GMT rather than +8. I would definitely like to see this "fixed" in a future FW.
DaveC
