No airframe symbols in RB24 Apps
Started by neroon79, January 29, 2015, 07:18:21 PM
Currently there are no airframes in the RB24 android apps. RB24.com seems not affected.
I've got 3 around Heathrow showing on the map and that's all. It says I've got lots of Nearby Flights, but it's not telling me how far away they are.
Perhaps someone needs to go and kick the server...
Meanwhile I temporarily got two in my area. As Rod stated many nearby flights, but all without a distance value.
Working OK now - server must have been kicked...  :-)
Yesterday evening I informed airnav that they have to "kick" the server.
Either they have kicked it or it have cured itself.
Will have a look if it's working for me too.
Elite-Login back to normal speed.
Aiframe count (almost) matches up with FR24.
So, indeed back to normal operation
Just noted the post, when I switched on the computer earlier there was no network.  Advised Andre and the server was restarted around 0900 UK and everything OK
