registration box
Started by mdobuk21, February 10, 2015, 07:35:24 PM
mdobuk21
evening
can anyone tell me how you can turn off the password/username registration box off in initial start up? I have totally forgotten!!
thanks
Mark
#1
I am not aware that you can
At first you have to select remember password/Username in this login box.
After that copy a shortcut to desktop (e.g.)
Then enter preferences menu(bottom of the option list) of this by using right mouse click.
In fild target add the bold text Yourdrive:\YourFolder\AirNav Systems\AirNav RadarBox\ANRB.exe" /connect
That way the software directly goes fully operational without the "login-window"7
If that is what you wanted to know.
MrParanoia
If you mean you can't remember your login details to be able to use the software then you will need to contact support if you have misplaced your cd sleeve.
That's a great tip Ingo, it was a slight niggle having to sit and wait for the databases to load so I could then start the program before leaving the PC unattended.
Radarbox 3D, GlobeS RTL1090, ModeSMixer2, UBC800XLT, UBC125XLT
