0 Members and 10 Guests are viewing this topic.
I am on my travels to Spain in the morning so will be offline until Friday afternoon.  Andrew (Orkney) will be looking after you until I am back online.
X
I have done the updates for last two days but see no changes on the db, as I use it to keep track of what I have sent you..... any reason?
X
X
PS Safe trip to Spain, see you sometime when we are both back in the old country
X
Kenny
Hi Andrew,
8838EE  HS-NGN Boeing 737-89P/W c/n 30681  ex N1786B, B-5100, 2-TBXP  op NewGen Airways
Kenny
ANRB 3km north of VTBD
Good morning Andrew only unknown on Monday was:
3FF59D  DMMPB (4x received) still no luck with the details at my end.
Please let me know wether you do route updates or not.
Thanks!
Regards Ingo
Unknown routes Batch 1: A to I
BER6757 AB6757 EDDH EDDL
CAI1333 XC1333 LTAI EDLP
CAI1334 XC1334 EDLP EDDE LTAI
CAI1881 XC1881 LTAI EDDV
CAI1L XC21 LTAI EHAM
CFG4803 DE4803 variable routes
CFG7TA DE1770 EDDV LCLK
CFG7YM DE1771 LCLK EDDV
CFG9PF DE1554 EDDV LEJR
CND1192 variable multi leg routes
EIN665 EI665 LOWW EIDW
EWG078 EW78 EDDK EDDP
EWG079 EW79 EDDP EDDK
EWG15X EW2045 EDDH EDDS
EWG1ZM EW276 EDDK LOWS
EWG2GW EW277 LOWS EDDK
EWG57F EW7405 LFPG EDDH
EWG7402 EW7402 EDDH LFPG
EWG7527 EW7527 GCFV EDDH
WEG9G EW343 EGCC EDDK
EWG9TW EW284 EDDK LOWK
GWI3EL 4U7044 EDDH EDDS
GWI7TB 4U7045 EDDS EDDH
GWI7041 4U7041 EDDS EDDH
GWI8U 4U9712 EDDL LFSB
IBK3QT D83673 LEMG EKCH
IBK6650 D86650 LEPA ESSA
Batch 2: J to S
JTG494 J4494 LPMA EKYT
JTG9325 J49325 EKCH GCRR
JTG9797 J49797 ESOE GCLP
KLM1566 KL1566 LIMJ EHAM
KLM447 KL447 EHAM OBBI OKBK EHAM
KLM452 KL452 OMAA EHAM
LOT8845 LO8845 EKCH EHGG
MYX8244 LEST EVRA
MYX8245 EVRA LEVT
MYX8501 EETN LEPA
MYX8502 LEPA EVRA
MYX8556 LPPD EVRA
MYX8559 EETN LEVT
NLY116 HG116 EDDK LBSF
NLY128F ferry flights
PGT51UG PC980 EDDB LTFJ
PRI8523 PF8523 EKYT GCFV
PRW248 6F248 Variable Routes
PRW719 6F719 ESSA LEMG
PRW782 6F782 GCVF ESGG
ROT374N RO374 EBBR LROP
RYR3679 FR2679 EDDH EGSS
RYR5KH FR181 EDDB EDDK
SAS534 SK534 EGLL ESSA
SAS59T SK647 EKCH EDDH
SXD4620 XG4620 HEMA EDDK
Batch 3: T to Z
TCX1414 MT1414 recently variable routes
TRA5617 HV5617 EHAM LIBD
TRA5618 HV5618 LIBD EHAM
TUI2047 X32047 LEMG EDDV
VKG1293 DK1293 LCLK EKBI
VKG4517 DK4517 variable routes
WZZ3701 W62091 EHEH EPLB
WZZ460 W63018 EGPF LROP
WZZ571 W62310 EDDV LHBP
That's is
FIN8907 AY8907 EFHK GCFV
WZZ531 W61651 EPGD EBCI
DLH4AE LH2053 EDDT EDDM
DLH1VR LH843 EKBI EDDF
DLH3AC LH3 EDDH EDDF
Kenny,
HS-NGN is already in the d/b
Will have a check X, only reason I can think of is if the updater is not working
X
Downloaded todays update and as far as I can see the updates are ok with the changes, additions and deletion of the last few days all incorporated.  As an example from your Tu-154 part 2, RA-85510 To RF-91822 current Russia - Air Force  is showing in todays Navdata as RF-91822 with the ones on either side of it in your list having been deleted and are no longer showing.
What makes you believe that this is not the case?
orkney
Hello Terry and Ingo
Terry, That ones have been updated.
Ingo, All your routes are done apart from the variable ones.
Andrew
