Author Topic: Database Update Requests  (Read 6119175 times)
0 Members and 81 Guests are viewing this topic.
orkney
  • Database Updater Moderator
    • orkney radarbox screenshot
« on: April 08, 2015, 03:42:37 PM »
Hello
This is a new Database Update Requests thread since the old one is now large and unwieldy so has been locked.
Thank you in advance for your requests.
Andrew
Re: Database Update Requests
« Reply #1 on: April 08, 2015, 03:56:28 PM »
Keith,
I added this one to the database as N306NV when it was around Leeds and it was showing as N306NC on the map on the network but I only got a fleeting glance before it timed out.  When it came into myflights as the hex was new it autpopulated with the info N306NV etc I had added and was using the flight ID LASHAM.  Attached is a screenshot of it from Radarbox24.
Where the problem arose I don't know as N306NC isn't in the database and isn't showing in my mylog or my Navdata.  It may even have stemmed from the aircraft itself using N306NC instead of N306NV.  N306NV was not in the database until I added it in this morning following receipt of an email advising the it had left Southend.
The only other thing I can think of is that I had it in the database incorrectly as N306NC which is possible as C and V are next to each other on the keyboard and the autopopulation has over written the error.  This is possible as I thought that I had previously entered it in the database before today and will probably have searched for it by registration.  When I didn't find it I will have re-entered it correctly this time.  For used aircraft I usually search by c/n to enable me to delete the old ID as well but its former EZY details are not there which leads me to believe I entered it incorrectly.  Any problems with the d/b are usually the result of my screw ups!!
Someone who didn't pick up the aircraft and has a current Navdata update may be able to advise if A336DC is showing as N306NC on their database and that would confirm my now corrected error.
« Last Edit: April 08, 2015, 05:32:14 PM by Runway 31 »
« Reply #2 on: April 08, 2015, 04:00:25 PM »
Cheers Ian
Northern Watch
« Reply #3 on: April 08, 2015, 04:20:25 PM »
Hi Alan
That makes sense, it certainly had me confused as I thought it was some sort of bug.  I also checked a few other aircraft in and around the time of tracking the Allegiant but all were as per the db.  I will amend Mylog.
Keith
CYYZGUY
« Reply #4 on: April 09, 2015, 12:44:23 AM »
Hi Alan, I have a flight missing some info..
Mode-S AA95CA
Flight ID N781RX
No Registration or Aircraft type populating.
regards,
Jason
40" LED Monitor
40" LED Monitor
« Reply #5 on: April 09, 2015, 06:04:17 AM »
Hi Jason,
AA95CA decodes to N781RX and this is N30AB LJ45 re-registered.  FAA record shows that the change was authorised 20/02/15.
oliver14
« Reply #6 on: April 09, 2015, 08:39:55 AM »
Just for information, I see Flybe are sub leasing a number of Dash 8 aircraft from Republic airways with a change of reg.
http://www.jethros.org.uk/fleets/fleet_listings/flybe.htm
« Reply #7 on: April 09, 2015, 03:45:59 PM »
The first one G-PRPL registered yesterday
« Reply #8 on: April 09, 2015, 05:41:45 PM »
Alan,
Just noticed your reply above and can confirm that A336DC is showing in my d/b as N306NC.
« Reply #9 on: April 09, 2015, 06:04:57 PM »
Cheers Ian, my screw up confirmed but it was changed after take off so is OK in todays update.
« Reply #10 on: April 09, 2015, 07:06:15 PM »
Alan,
TAP1305 : LKPR-LPPT
JAF9JG : EBBR-LEAL not GMFO-LFPO
Quite a number of unusual routings over this way during the last few days due to the French ATC strike just wish the weather was better and I could actually see them !
« Reply #11 on: April 09, 2015, 07:09:25 PM »
Cheers Ian,
Never mind I will be out on Sunday to blow the clouds away!!
« Reply #12 on: April 09, 2015, 07:10:45 PM »
As stated above I am off on my travels to Spain first thing and will be mostly offline until late Sunday.  Orkney (Andrew) will look after you till Monday morning.
« Reply #13 on: April 09, 2015, 07:18:25 PM »
Cheers Alan.
Bring your heavy overcoat and wellingtons !
Pint with your name on it awaits.
Safe journey.
« Reply #14 on: April 09, 2015, 07:37:47 PM »
That will do for me Ian, speak soon
