0 Members and 14 Guests are viewing this topic.
orkney
Hello Falcon, Michel and M
That is them all in.
Andrew
Undertaker
9H-VJL appears to be incorrect in the DB as 9H-VJK was noted Northolt to Farnborough as Hex 4D20D8 this morning
orkney
Hello Undertaker.
That should be That one Fixed.
Thank you
Andrew
flygfantast
Andrew
4AD9E4 SE-VOD, Aerospool WT9 Dynamic, c/n DY-283/2008, Swedish Ultraflyers
Niklas
Cable: Ecoflex-10 (10m+1m)
orkney
Hello again Niklas
That is it in now too.
Thanks once again
Andrew
Evening Andrew,
WOW616 : BIKF-LEAL
WOW617 : LEAL-BIKF
orkney
Hello Ian
That is them added.
Andrew
falcon_nl
Found one:
4407E9, OE-FMX, DA42, Diamond Aircraft DA-42,  42.MN038, Diamond Aircraft Industries GmbH
orkney
Hello Falcon
That is that one in now too.
Andrew
M
PAL722   RPLL   EGLL
PAL723   EGLL   RPLL
BTI7CP   EETN   EVRA
FIN110   EETN   EFHK
FIN3KL   EFHK   EFIV
FIN9RJ   EFHK   GCLP
FIN9K   EFHK   LEPA
FIN966   LEPA   EFHK
Michel
Andrew,
TRA582 LTAI-EHAM
TFL418 DTTJ-EHAM
MPH9761 EHAM-UAAA-VHHH
Michel.
orkney
Hello M and Michel
That should be all of them done.
Andrew
M
SAS890   ENVA   ESSA
SAS891   ESSA   ENVA
SAS2022   ESSA   ESPA
NTJ1552   ESSA   ESNG
FIN267   EFHK   EFTP
FIN3Q   EFTP   EFHK
FIN47P   EFHK   EFTP
FIN272   EFTP   EFHK
FIN8ZR   EFHK   EFKU
FIN520   EFKU   EFHK
FIN9J   EFHK   EFTU
FIN228   EFTU   EFHK
FIN221   EFHK   EFTU
FIN6LX   EFTU   EFHK
Michel
Alan,
VLM51RM EHRD-EDDH
VLM52MR EDDH-EHRD
VLM57RM EHRD-EDDH
VLM58MR EDDH-EHRD
Michel.
