0 Members and 176 Guests are viewing this topic.
Alan,
I thought that might be the case. However, it's a bit of a mystery as '34' is the hex for Spain but that flight ID could be something to do with United States Marine Corp (USMC) !
Possible CASA low test flight at Muchamiel ?
shouriken
018080 - 5A-FLA - RJ1H - British Aerospace Avro RJ-100 - Air Libya - cn E3232 (ferry flight LRCV-HEBA)
4A4D65 (YR-SKE) and 4A4D72 (YR-SKR) temporary registration to move them from LRBS to LRCV (ex EZ-A002 and EZ-A003)
Liviu
A.net JetPhotos.Net
RadarBox
Many thanks Liviu, much appreciated
Afternoon Alan, unknowns from Monday (a lot of MIL)
3C09D9 nothing more
400B59 G-VKNG no active airframe with this reg/hex
478356 nothing more
484158 http://www.live-civil-mode-s.eu/search/popup.php?zoekstring=484158
4844EE PH-MPR no active airframe with this hex/reg
4BAD99 nothing more
505DB0 nothing more
81333D nothing more
AE26D2  BUZRD55 US MIL
B303C1 no country allocation
C85061 nothing more
EE9810 no country allocation
MILs:
* 3E80BD  GAF264                                                         2015/06/08 07:32:58
* 3E8553  GAF120                                                         2015/06/08 09:58:52
* 3E987B  GAF078                                                         2015/06/08 07:29:46
* 3E987B  GAF078                                                         2015/06/08 08:25:19
* 3E987B  GAF078                                                         2015/06/08 11:28:19
* 3EB0AF  PUMA                                                           2015/06/08 08:15:16
* 3EB0AF  PUMA                                                           2015/06/08 09:44:43
* 3EF42D  D5014                                                          2015/06/08 11:32:25
* 3F400A        2015/06/08 09:08:39
* 3F4039        2015/06/08 08:48:10
* 3F4039  COUGAR                                                         2015/06/08 13:40:56
* 3F4D3E  JUSTICE                                                        2015/06/08 08:30:43
* 3F4D3E        2015/06/08 13:16:25
* 3F6604  STRIKE                                                         2015/06/08 13:44:49
* 3F6604        2015/06/08 14:32:44
* 3F84B9        2015/06/08 11:26:29
It seems that the fruitful days are over for now.
Regards Ingo
jim_stockwell
Afternoon Alan
A couple not populating from today are HEX 4D2103 AND 43D277. Sorry no other info shown
Jim
Michel
Alan,
TFL210 LGZA-EHAM iso LGMT-EHAM
CND292 LGRP-EHAM iso LWOH-EHAM
Michel.
Evening Ingo,
AE26D2,88-0444,1C-046,General Dynamics F-16C Fighting Falcon,US - Air Force
3EF42D,D-5014,412,Schempp-Hirth Duo Discus, tucked away in the middle of the mil tac
Nothing on the others 484158 PH-DMC is long broken up.  Mil tac added
Hi Jim
4D2103,9H-JOY,7644,Canadair CL-600-2B19 Regional Jet CRJ-200ER,Air X Charter  I had it in with the hex corrupted, now corrected.
43D277 is probably 43C277 miscoded in which case it will be ZJ226 Apache but not confirmed.
About 3EF42D,D-5014:
I went thru the log on my smartphone during my lunch-break and said to myself: Today afternoon you must be careful  not to copy D5014 along with the MILs. So much for that...
No worries Ingo, after a hard day its easy to miss.
flygfantast
4AD718 SE-UXX, Binder-Ash25EB, c/n 25190, Private owner
Niklas
Cable: Ecoflex-10 (10m+1m)
X
#1034
A6551F is showing US reg, assume old one and saw a chopper SE of UUEE possibly the one noted yesterday and two decidedly dodgy US codes
    30040D        2015/06/09 20:46:18
    A6551F  N507NB                                                    2015/06/09 14:43:27
    ABC123        2015/06/09 17:11:38
* ABCDEF        2015/06/09 18:56:18
X
