0 Members and 97 Guests are viewing this topic.
#10230
3EEF2F D3736 D-3736 Glaser-Dirks DG100 http://www.onlinecontest.org/olc-2.0/gliding/flightinfo.html;jsessionid=57FB7874DAEDF1736FF5BB1080436BBC?dsId=5375594&c=AT&sc=stk and mentioned on Fa-ce-book.
Regarding TRA6463 / TRA3Z:
Went through my log and dug out the following:
   48520D  TRA6463                  PH-HXE     B738  Transavia Airlines   2017/04/27 05:09:22
   48520D  TRA3Z    LGSM-EHAM       PH-HXE     B738  Transavia Airlines   2017/04/27 12:27:12
   484C5A  TRA6463                  PH-HSC     B738  Transavia Airlines   2017/04/24 04:33:30
   484C5A  TRA6464  LGSR-EHAM       PH-HSC     B738  Transavia Airlines   2017/04/24 10:59:31
TRA6463 HV6463 for leg EHAM LGMK LGSM departing EHAM early morning on April 27th (see first log excerpt).
They leave out the LGMK stop on every second rotation.
In that case the return flight is HV6464 using TRA6464 flight id.
Unfortunately they use TRA6463 flight id for both variants.
(see second log excerpt of April 24th)
Is it possible to add LGMK in "()"...
TRA3Z HV6463 was used for return leg:  LGSM EHAM in the afternoon, this part had already populated (see first log excerpt).
They did the same on April 20th.
same  IATA two different ICAO and two variants for one ICAO: Thank you Transavia!
Agree with the SWR5xxx. Aircraft was HB-JMK. Seems that we won't hear much from that airframe from now on: http://www.airfleets.net/ficheapp/plane-a340-169.htm
D-ATYA populated as it should on my 24/7 computer but didn't on the other. I love computers and software.
3EEF2F,D-3736,28,Glaser-Dirks DG-100
Thanks for the explanation for the routes, they don't like making things easy as you state, (LGMK) wont work as the server routine would be confused and wouldn't know what to do so we will need to have the routing wrong every second week
falcon_nl
Here's my list from today:
3FF403, D-MNJI, BREZ, Aerostyle Breezer
485211, PH-4M5, 097S, SKAR, 3-i Sky Arrow 450 TGS
48538A, PH-1581, 3026, GLID, RSchneider LS 3
484168, PH-1432, 10-134S86, DG1T, DGFlugzeug DG-1000S
3DDE5D, D-HELP, 12500, R44, Robinson R44 Clipper II
3FEFEE, D-MIAX, AP22, Aeroprakt A22L2
3E7E83 callsign D-KNCL (DUOD ?)
3FEC23 callsign DMORT
3E6740 callsign DKEHK
042A1A callsign 00000000
4A09A9 callsign BMS7R
5110DA callsign FRX600
Ingo,
3EE556,D-1215,,Glaser-Dirks DG-300 the one I have details of c/n 3E226 is now PH-1556
D-MFTG unknown to me
3FF31D,D-MADS,1406-7335,Ikarus C42,Flugschule Worms
3FF405,D-MFVE,,Ikarus C42
D-MQKA unknown to me
3FF4A3,D-MMBT,,Aero East Europe SILA 450C
D-MHCY unknown to me
3FF55F,D-MGIY,,Nando Groppo Trial
Many thanks again
Evening Terry, thanks again
Haven't forgotten your post X
Hello Falcon, Alan
3E7E83 callsign D-KNCL Duo Discus T (OLC, October 2016) http://www.rcawsey.co.uk/duodis.htm
3E6740 callsign DKEHK D-KEHK Lange E-1 Antares 20E last mentioned at OLC in 2015
3FEC23 callsign DMORT D-MORT was a Tecnam P.92S Echo at least until 2011
* 4A09A9  BMS7R    LROP-LFOB       YR-BMI     B738  Blue Air             2017/04/29 07:00:59
http://www.airfleets.net/ficheapp/plane-b737ng-27989.htm
Evening falcon
3E7E83,D-KNCL,11/257,Schempp-Hirth Duo Discus T
3E6740,D-KEHK,02,Lange E1 Antares
042A1A,3C-MAB,60016/1258,Boeing 777-2FBLR,Ceiba Intercontinental
4A09A9,YR-BMI,27980/45,Boeing 737-8K5,Blue Air
Nothing on the others
Thanks Ingo,
Just seen your post and forgot to check the database for D-MORT until I saw it and we already have it in it
3FEC23,D-MORT,,Tecnam P92 Echo 2000S
Yes but that will take a bit of work Ingo.  Have a good evening
Michel
Alan,
CFG3DL EDDH-GCLP
CND217 EHAM-HEGN
EXS75K EGNT-LIRP
PRI574 LEMG-EKCH
PRI584 LEMG-EKCH
TOM9PT EGPH-LCLK
Michel
