0 Members and 29 Guests are viewing this topic.
Evening terry, thanks again
falcon_nl
#10276
Evening Alan,
Here's again a list from today:
48558C, PH-ITI, 8378, AS50, AirbusHelF AS 350 B3
3FF5A4, D-MMXL,,, Pelegrin Tarragon
3FEB9D callsign DMQPA
3FF4FB no callsign
3FEE4D callsign DMIDB
Evening falcon
3FEE4D,D-MIDB,0804-6944,Ikarus C42B
3FF4FB,D-MFVB,9701-6022,Ikarus C42 Cyclone
Nothing on the other
#10278
Morning Alan,
LLP8770 : LEMG-EPWA
LLP8769 : EPWA-LEMG
EVE7837 : LEPA-GCXO
EVE7838 : GCXO-LEPA
TRA6623 : EHEH-LEAL
TRA6624 : LEAL-EHEH
LAV5281 : LEPA-LEMG
LAV5282 : LEMG-LEPA
TOM31G : EGCN-LEAL
Good morning to you on this lovely morning Ian, thanks again
Alan,
Perhaps not quite so lovely. It would appear that Thomsons have changed all their flight numbers again. I was going to say can you check out the arrivals at your end but your not at your end are you ? You're at this end. Perhaps the network will help. Too many leaving at this end around the same time to be able to confirm.
TOM2TJ : LEAL-?
TOM26G : LEAL-?
TOM4TL : LEAL-?
RYR7 : EIDW-LELC
RYR7GD : ESGG-LEAL
TLB764 : LFOK-DAOO
EIN80C : LEAL-EICK
I think they just do that to toy with our heads Ian.  I thought I could leave TOM flights apart from Greece/Turkey which have only recently started, ah well back to the drawing board.
TOM4TL is  LEAL-EGCC
Alan,
It's all good fun.
EXS583 : EGNT-LEAL
EXS582 : LEAL-EGNT
BMS8P : EGGP-LEAL     new service
BMS6R : LEAL-EGGP
TOM5LC : LEAL-EGCN  I think !
TOM3ME : LEAL-?
MON731 : LEMG-EGKK
MON732 : EGKK-LEMG
Ian,
EXS582 should I believe read EXS584 as the 582 operates out of Rhodes on a Thursday or Friday
TOM5LC is LEAL-EGCN
Alan,
The Jet2 is EXS584. It's that syndrome again.
Some additions/amendments :
c/n 1784 A330 is a new Iberia EC-MOY. Not sure if it has been delivered yet.
c/n 22177/16 B757 G-BIKF of DHL is permanently retired at Madrid.
c/n 525-0396 D-IKCS has been sold as EC-MPN. Current Spanish register is not showing the new owner and new hex not known.
Ian,
I can see 2 or 3 TLP trails over your way but nothing showing
EC-MOY due this month
G-BIKF was deleted from the d/b previously
EC-MPN nothing on it yet
Good afternoon/evening Alan, Mondays unknowns:
* 3451D7  VLG18MG  LEMG-EKCH                                             2017/05/01 16:59:48
* 3451D7  VLG18NH  EKCH-LEMG                                             2017/05/01 19:51:16
was caused by 3451D3 EC-MKM , same error, two times, should be monitored if it happens again. If yes possibly miscoded in one box.
3E476F  DISGD still no luck with the details
3FF4F2  DMMYF no luck with the details
Regards Ingo
Mondays Routes:
AMC386 KM386 LMML EHAM
AMC387 KM387 EHAM LMML
CAI1TG  XC1334 EDLP LTAI
CAI98NF XC1333 LTAI EDLP
CAI7RQ  XC1984 EDDE LTAI
CAI8DQ XC1881 LTAI EDDV
CFG3YF DE4787 variable routes
CFG4789 DE4789 variable routes
CFG7HL DE1632 EDDH LGKR
CFG7KY DE1633 LGKR EDDH
EWG032 EW32 EDDK EDDH
EWG033 EW33 EDDH EDDK
EWG4WE EW9971 LDZD EDDL
EWG6FW EW7675 LGIR EDDH
EWG7674 EW7674 EDDH LGIR
EWG7MH EW677 LGIR EDDK
EXS44C LS944 LCLK EGCC
GWI3FY 4U9752 EDDL LOWW
GWI3YB 4U9750 EDDL LOWW
GWI6RB 4U9751 LOWW EDDL
KLM1162 KL1162 ESGG EHAM
LOT012 LO12 KEWR EPWA
MON1260 ZB1260 EGNM LTBS
MON3425 ZB3425 LDZA EGCC
PRW247 6F247 variable routes
PRW701 6F701 ESSA LEAL
PRW702 6F702 LEAL ESSA
PRW720 6F720 LEMG ESSA
TAP762 TP762 LPPT ENGM
TCW2VZ HQ1582 EBBR LGKR LGZA EBBR
TCW6FC HQ1649 LGSA EBBR
TCX67HW MT1261 LGKO EGCC
TRA6425 HV6425 ESSA ????
VKG1292 DK1292 EKBI LCLK
VKG9013 DK9013 LMML ENGM
No WIZZ again  very unusual.
Nothing on your unknowns Ingo
Regarding the VLG, did you also pick up the correct code on each occasion
#10289
yes, correct hex received with same flight id at same time. Several 100 messages received. But no ADS-B for false hex. Correct hex with 1000+ messages received. ADS-B positiv for correct hex.
So more likely a decoding error. So better no action just monitor.
EDIT: I had problems with remote connecting via hotspot earlier. Thankfully it worked now, so I could check mylog.db.
