0 Members and 130 Guests are viewing this topic.
Morning Keith
C02E9B / c/s SKV7062.  decodes to C-FRQW but nothing on the Canadian register
4CA836 not allocated
40F50B not allocated/unknown to me
401300 not on G-INFO so not allocated
Above may be miscodes but the middle 2 are more likely decode errors/corrupt packets
Morning Alan,
MAC338 : LFMT-GMFF
VLG12AV : LEAL-EGFF
VKG4036 : EKCH-GMMX
PRW705 : ESSA-LEAL
PRW706 : LEAL-ESSA
superspotter
Another miscode in Lagos. I was becoming confused this morning when I kept seeing Hexcode 040087 climbing and descending. When I checked, I could see the correct assignation of this hex, over the Atlantic in the shape of Ethiopian 787 ET-ARE.
Now, as the hex appeared again, descending, it turns out that Aerocontractors DH8C is the culprit. They only have the one 5N-BJO.
Such a mess, these hexcodes in Nigeria!
regards clive.
Hi Clive,
I have 044045 in the database presumably from you as 9G-AEU miscoding from its correct 044043
5N-BJO should use 064087
Afternoon Ian, thanks again
hunter2021
Quote from: Runway 31 on May 06, 2017, 04:34:35 PM
There is no problem with the registry hunter.   The problem with 38001B is that it is a French hex code being used on a Venezuelan registered aircraft which should use an 0D**** hex code.  This is further compounded by the fact that 38001B is allocated to F-PEDP and is being used correctly by that aircraft in France.
As it is being used correctly by F-FEDP and as a miscode by YV2308, this hex is now in the database as follows
38001B,VARIOUS,N/A,Being used by more than one airframe,Being used by both F-PDEP RBEL and YV2308 AT43)
YV3027 has been corrected
Thank you friend, sorry
greeting
Cheers hunter no problem
Keith
SKV7062 C02E9B,C-FRQW,17000154,Embraer 170-200STD-175STD,Sky Regional Airlines/Air Canada Express ex SP-LIF
Alan,
Unusual one here for which I can find no arrival details into Spain :
TSC267 : LEBL-LEMG-CYUL
Ian,
Came over yesterday CYUL-LEBL as TSC266
Thanks Alan.
MON264C : EGKK-LEAL
Evening Terry, many thanks.
Thanks Ian, recycled through
Morning Alan,
EXS14A : EGSS-LEAL
PRI493 : EKBI-LEAL
PRI494 : LEAL-EKBI
PRI411 : EKCH-LEAL
PRI412 : LEAL-EKCH
NOS520 : LEMG-LEPA
Morning Ian, thanks again
