0 Members and 18 Guests are viewing this topic.
CarlosAbreu
Good morning Alan
Some charter cies keep same flight code but sometimes change route, for ex Privilege Style flow as PVG5774 GFMO-LPPT in 11/6 and yesterday PVG5774 was LPPR-LEIB. Data confirmed by double check at Porto Airport departures.
I have an Excel file daily updated with all flights that I manually post here but it includes a lot of notes about changes in some of them that can be usefull to you.
From now on I will post here daily flight information in an attach Excel file. Is it fine to you ?
Carlos
Cable: Ecoflex 10 (15m)
Station: XRange2 PGANRB501386
Antenna: Airnav Systems
Cable: LBC240 00220M (15m)
Whatever is easiest for you Carlos, I don't mind
hunter2021
#11087
CONFIRMED
0D82C6
YV3319
C550
http://rzjets.net/aircraft/?reg=449148
According to my photographic file it has the same EX N37HF
Yes looks the same.  N37HF was exported to Venezuela in 2015 so should be c/n 550-0733 which makes it a C550 and became YV583T I believe
Tykes Aero Blog
Seems to be an issue with the Boeing's.  B-1410 is showing on 7810F8 for some reason instead of B-1419.  781126 is B-1410 (originally posted as B-1401 on my blog as a typo).
B-1419 is CSN.
B-1410 is CCA.
Thanks Tyke 7810F8 B-1410 was typo on my part but noted and fixed this morning in the d/b.
Unless your blog is wrong
B-1410 is CSN
B-1419 is CCA
Thanks for advising
Good evening Alan, Fridays unknowns:
3C06C1  DCS801 D-AROM E35L DC Aviation GmbH https://www.flickr.com/photos/guernseyairportphotography/34777834532/
MILs:
   3E8C04  GAF639                                                         2017/06/23 07:41:38
* 3EA905  GAF403                                                         2017/06/23 14:16:07
* 3EB4D5        2017/06/23 09:12:14
* 3F7C10  SCARE1                                                         2017/06/23 07:21:07
* 3FB4D2        2017/06/23 08:10:07
* 3FB4D4  PIRAT                                                          2017/06/23 08:08:13
* 3FB4D4  PIRAT                                                          2017/06/23 09:07:33
US MIL: AE57D7  PAT311, PAT: Department of the Army, Priority Air Transport
Regards Ingo
Evening Ingo
3C06C1,D-AROM,14501132,Embraer ERJ 135BJ Legacy 600,DC Aviation
AE57D7,10-00261,BL-169,Beech C-12V-1 Huron,US - Army identified at Glasgow
Mil tac added
CarlosAbreu
File in attach with 24-06-2017 flight regist.
Please let me know any doubt about the file.
Carlos
Morning Carlos, thanks again
Tykes Aero Blog
Quote from: Runway 31 on June 24, 2017, 07:25:19 PM
B-1410 is CSN
B-1419 is CCA
Thanks for advising
Those OPR tie-ups are correct, sorry for confusion above.
No worries, easy done
Good afternoon Alan, Saturdays unknowns:
3D4096  DEWSC received again
3FF431  DMNSK http://www.aviationfanatic.com/ent_show.php?ent=5&AC_Regno=D-MNSK
3FF529  DMFOE (3x) no further information
Regards Ingo
Afternoon Ingo
3FF431,D-MNSK,,Albatros 64,,,ULAC
Nothing on the other two
