0 Members and 157 Guests are viewing this topic.
CYYZGUY
Hi Alan, maybe you can help me out with this unknown.
Only Mode S
C01A2C
regards,
Jason
40" LED Monitor
40" LED Monitor
Hi Jason,
C01A2C decodes to C-FJXR and a look at the Transport Canada website shows that it is not allocated.
M
FIN9   EFHK   KORD
FIN10   KORD   EFHK
FIN627   EFHK   ESSV
FIN628   ESSV   EFHK
JTG901   EKBI   EFHK
JTG902   EFHK   EKBI
KAL583   RKSI-ULLI-EDDF-LIMC
falcon_nl
Unknown:
47C5C6 (callsign: NAX8881)
falcon,
47C5C6 decodes to LN-LNC so B788 EI-LNC registered back to Norway
falcon_nl
Thanks Alan,
Found a new one:
4850F3, PH-CAL, GLSP, 0099, Glasair Sportsman 2+2
54901 - Jim
Hello, Alan!
I've been missing from here for many months and decided that today was the day that my RadarBox and I would be reconnected. I'm running w/ the latest software, but am in need of the newest database updates. I've scanned a lot of messages and discovered from posts that the updates are available on a daily basis ... WOW! But I can't seem to find where to get them? Help!
Thanks!!!
Jim
KOSH - Oshkosh, Wisconsin USA
falcon_nl
Hi falcon,
49D24D OK-UWE is already in the d/b.  SR22 c/n 4216
Hi Jim,
Nice to hear from you stranger.
You get the updates from File/Database Explorer and you will see a tab marked Database Updates.  Click on the tab and make sure all the tables are ticked then choose the option Update All Records and press Start Update.
You will see a green progress bar going left to right and when it finishes processing of the update starts and after a few moments you will be told to Restart.
Close down RB and restart, this will finish the process and on starting up again it you go to Database Explorer/Tables and click on the Aircraft Table on the bottom left you should see a figure of just over 231,000 records if all has went well.
As you state a new d/b is available each night and its up to you how often you update.  All the other tables get updated as well but it is only really the Aircraft and Routes Tables which see routine activity.
Michel
#1122
Alan,
MAS6124 WMKK-OMDW-EHAM iso WMKK-OMSJ-EHAM
GWI37L EIDW-EDDL iso EIDW-EDDS
QTR275 OTHH-EHAM
QTR276 EHAM-OTHH
ETD28 EGPH-OMAA
Michel.
falcon_nl
#1123
Unknown:
505CB2,  DMDTR
60005F
54901 - Jim
Here's one for you, Alan ...
A4C0A3 / N405QS / GLF4 / Gulfstream 450 / NJI Sales Inc / 4054
Thanks!
