0 Members and 23 Guests are viewing this topic.
CarlosAbreu
28-06-2017 file in attach.
Carlos
Cable: Ecoflex 10 (15m)
Station: XRange2 PGANRB501386
Antenna: Airnav Systems
Cable: LBC240 00220M (15m)
Morning Carlos, thanks again
Morning Alan,
Got back to the rain safely then ?
MAC123 : GMMW-EHAM
MAC126 : EHAM-GMFF
RYR78CV : EDSB-LEAL
SXD3730 : GMMW-EDDL
EZY7426 : LELC-EGMC
EZY7425 : EGMC-LEAL
PRI447 : EKCH-LEAL
PRI448 : LEAL-EKCH
Hi Ian
Roll on September, heating is on, 14 degrees, freezing!!
Alan,
It's only 28c here today at the moment. I've had to put my vest back on !
The unknown 34334A is back on again. This time he has added a flight id of GPM21G. The 'GPM' code relates to 'Group Air Med'.
Also, presumably on a test flight out of Seville with full ADSB and already in the d/b is E49273 a CASA295M with registration 6550 and flight id of BRS6550 of the Brazilian AF.
Thanks again Ian, I over stated the temp its only 11 brrr!!
Regarding 34334a presumably this company with BE20 and P68 fleet http://grupairmed.com/index.php/en/mnflotaen
I haven't been able to find out a c/n for the Casa yet
Afternoon Alan,
Yep, that is the company. Strange that in one of their photos they have blanked out the aircraft registrations.
As to the Brazilian Casa, the c/n would appear to be S-157 :
http://www.airfighters.com/photo/191992/L/Brazil-Air-Force/CASA-C-105A-C-295/6550/
Thanks for that Ian, its designated a Casa SC-105A in Brazilian service
Evening Alan, Wednesdays unknowns:
3D6A44  DFMMM received again
MILs:
* 3EA374  MITY02                                                         2017/06/28 07:43:32
* 3EA374        2017/06/28 08:36:54
* 3F9D76  GAF166                                                         2017/06/28 06:22:15
* 3FA483  HORNET02                                                       2017/06/28 07:22:58
* 3FB2B2  HORNET01                                                       2017/06/28 07:13:03
C04864  CGBKT maybe it is this one http://registry.faa.gov/aircraftinquiry/NNum_Results.aspx?omni=Home-N-Number&nNumberTxt=N134EB to finally become it.  http://www.laasdata.com/turbos/turbo-by-type.php?t=27 so, no need to add it in I guess.
Regards Ingo
Evening Ingo,
Nothing yet on D-FMMM, MIL TAC ADDED
No its not N134EB it is C04864,C-GBKT,510-0446,Cessna 510 Citation Mustang,Jet-Share Aviation ex D-ISXT presumably leaving on delivery
Evening Terry, thanks again
AoD
BUC6217   LBWN - EDDV
CFG473   HEGN - EDDP
ENT1046   LICA - EPPO
ENT5904   LEBL - EPWR
EXS5SD   EGPF - LTBS
GMI2164   ETNL - LOWW
LLX5874   LGRP - EDDW
LOT5GA   EPWA - LKPR
WZZ4451   EGGW - LLBG
