0 Members and 106 Guests are viewing this topic.
Hello Alan, Wednesdays unknowns:
MILs:
* 3E910E  GAF639                                                         2017/08/23 10:01:43
* 3E979E        2017/08/23 08:23:44
* 3E979E        2017/08/23 09:23:03
* 3E979E        2017/08/23 13:06:20
* 3E979E        2017/08/23 14:00:27
* 3EA886        2017/08/23 06:19:21
* 3ED00B        2017/08/23 09:55:35
* 3F6BF2        2017/08/23 08:30:44
* 3F6BF2        2017/08/23 12:54:32
* 3F7068  SEAL                                                           2017/08/23 06:39:50
3FF427  DMVGT still no luck with the details
3FF553  DMEIK https://planefinder.net/data/aircraft/D-MEIK http://govfr.com/aircraft_D-MEIK-Z602_-1_5685.html
3FF5E6 DMNPA  AutoGyro MTO Sport
781156  CSN1000 this one https://xfw-spotter.blogspot.de/search/label/7818 on delivery. Already added I guess.
Regards Ingo
Evening Ingo
3FF553,D-MEIK,,Roland Z-602
3FF5E6,D-MNPA,,AutoGyro MTOsport
781156,B-8995,7818,Airbus A321-211,China Southern Airlines yes added on departure from XFW
Miltac added and nothing on D-MVGT.  I believe 3ED00B to be a glider but have no info so it remains unknown
3ED00B last received July 2015 with flight id DKTTB no further receptions until yesterday
D-KTTB was a ASH31 which was W/O 5.5.2016
nothing about a new one.
Evening Alan,
VLG1353 : LEIB-LEAL
VLG1354 : LEAL-LEIB
WLB5604 : LEMG-OLBA
WLB5603 : OLBA-LEIB-LEMG
RYR9AK : LEMD-LICJ
EZY7426 : LELC-EGMC
RYR52AK : LEMG-LIRF
MON522 : EGCC-LEAM
IBK2UP : LEBL-GCLP
That's correct Terry,  one is for Government purposes and one is for use by the King.  I will stick with my database unless Graham has inside information?
Evening Ian, thanks again
CYYZGUY
#11932
UAL1966 No Routing
https://flightaware.com/live/flight/UAL1966
FDX3035 No Routing  Aircraft shows as a DC10, however the photo shows a MD-11  (A7D69D, N604FE)
https://flightaware.com/live/flight/FDX3035
Also, another Canadian unknown..
C0737B, CGRTA
regards,
Jason
40" LED Monitor
40" LED Monitor
Hi Jason
A7D69D N604FE is an MD11 as per the Airnav database and FAA. http://registry.faa.gov/aircraftinquiry/NNum_Results.aspx?NNumbertxt=604fe  I presume that you are discussing the information and photos on Flightaware, sorry cant do anything about their error
C0737B,C-GRTA,175,Dassault Falcon 2000LX,Anderson Air
CYYZGUY
Wish I had taken a picture of it, but it said DC10 under aircraft type (my classic radarbox)....Strange....I am definitely running the most up to date database...
40" LED Monitor
40" LED Monitor
#11935
I have no idea what you saw on screen Jason I can only go with the database and as you can see its from the attached its shows MD11 and it has been like that since 2015.  Also no photo appears to be allocated as there is nothing showing in the lk or lk2 part of the d/b for it. What does your Navadata show for it and do you have a photo against the registration in your photo folder, have a look at it and delete it if it is incorrect.
CarlosAbreu
24-08-2017 Updated file in attach (no data for 23-08-2017).
Carlos
Cable: Ecoflex 10 (15m)
Station: XRange2 PGANRB501386
Antenna: Airnav Systems
Cable: LBC240 00220M (15m)
Kenny
Hi Alan
A86A93 41523 Agusta AW139 cn 41523  op Thailand - Army (Miscode N641SS)
A87201 41524 Agusta AW139 cn 41524  op Thailand - Army (Miscode N643SS)
Kenny
ANRB 3km north of VTBD
