1 Member and 36 Guests are viewing this topic.
Good afternoon/evening Alan, Sundays unknowns:
3E6087  DKBTF no further information
4C0672  YUBTS still no luck with the details
Regards Ingo
Good afternoon Ingo
I cant find anything on them either
Michel
Alan,
BOX290 EDDP-EGNX
CND193 EHAM-LTAI
TCX52HW LGKR-EGNT
TFL235 EHAM-LGKO
TFL821 EHAM-LTAI
Michel
CYYZGUY
#12036
Hi Alan, One of the performers at the CNE was a S58T/H-34 SIKORSKY HELICOPTER
http://cias.org/performers/
It is showing up as a S76 in my navdata and also live....
Here is the information I have that was showing , the database has old information I think.
C-FIGO  Mode S C015CB
Also, an unkown
Only Mode-S AA20E7
Only Mode-S C0635D
Cheers,
Jason
40" LED Monitor
40" LED Monitor
#12037
Hi Jason
C015CB is C-FIGO S76 http://wwwapps.tc.gc.ca/saf-sec-sur/2/ccarcs-riacc/ADet.aspx?id=529777&rfr=RchSimp.aspx  and is in the databse correctly
I downloaded the photo and got the S58's details, now added into the d/b
C05442,C-GFXP,58-0378,Sikorsky S-58ET,Four Seasons Aviation
C0635D is C-GLQI and is not allocated the previous holder a B06  being written off Near Loder Peak Alberta IN 2012 and was cancelled from the register.
AA20E7,C-GNKL,32R-7680273,Piper PA-32R-300 Lance,Vladislav Genov (Miscode hex of  N75157)
CYYZGUY
One last unknown for the evening
Only Mode-S  ADAEEF
regards,
Jason
40" LED Monitor
40" LED Monitor
CarlosAbreu
04-09-2017 Updated file in attach.
Carlos
Cable: Ecoflex 10 (15m)
Station: XRange2 PGANRB501386
Antenna: Airnav Systems
Cable: LBC240 00220M (15m)
Kenny
ADABED HS-BCF Cessna 172S  c/n 172S10546  ex N980JA  op Bangkok Aviation Center
Kenny
ANRB 3km north of VTBD
No idea on it Jason
ADAEEF decodes to N981AV not allocated by the FAA
Morning Kenny
ADABED is now currently allocated to N980JA DA42 c/n 42.277.  I would suggest that you update your database locally
Good afternoon/evening Alan, Mondays unknowns:
MILs:
* 3F429E  VADER51                                                        2017/09/04 12:44:44
* 3F6F6C  GHOST1                                                         2017/09/04 20:00:34
* 3F7255  STRIKE                                                         2017/09/04 08:26:43
* 3F9A2F        2017/09/04 13:53:06
   3FECCC  ZZZZZZZ                                                        2017/09/04 15:19:56
3FF427  DMVGT (2x) nothing new to report
3FF4E9  DMHCY it's the same with this one
488CD3  SPDGU http://www.airforcesmonthly.com/2017/08/07/germany-leases-m28-skytrucks/
4898C6  SPGGG no further information
Regards Ingo
