0 Members and 28 Guests are viewing this topic.
Alan,
The TLP. Currently in the air mode s only Hungarian AF SAAB Gripen 473C04 registration '33' and c/n 393304. Details are in the d/b already. Nothing else has been on.
hunter2021
0D0790
XA-LNP
GLF3
Gulfstream III
323
Private
Hello Alan, Tuesdays unknowns:
MILs:
* 3E8ACF  GAF072                                                         2017/09/12 06:18:01
* 3E8ACF  GAF072                                                         2017/09/12 09:15:11
* 3E8C0A  GAF303                                                         2017/09/12 06:18:58
* 3E8C0A  GAF303                                                         2017/09/12 09:08:02
* 3F590D  LIONT                                                          2017/09/12 07:58:12
* 3F590D        2017/09/12 09:41:24
* 3F605B  GAF029                                                         2017/09/12 08:50:46
* 3F61F9  GAF601                                                         2017/09/12 07:34:49
* 3F704F  ARMOR2                                                         2017/09/12 08:40:19
* 3F704F  BU02                                                           2017/09/12 14:49:31
* 3F743B        2017/09/12 06:29:42
* 3F9AF9        2017/09/12 13:34:09
* 3FA95E  GAF640                                                         2017/09/12 12:14:30
* 3FBC39  GAF640                                                         2017/09/12 07:11:12
Regards Ingo
Keeping their powder dry for me coming out next week Ian.  There will be more around but as you know, not many squit
hunter2021
XB-LRD
A127D2
T206
Cessna T206H
T20608799
Private
Hello Ingo
All added in, thanks again
mikek
A couple more here:
AE567C, R20529, 12-20529, UH-60M, US Army
AE567D, R20530, 12-20530, UH-60M, US Army
A6EBCC, N545PH, MDH 369E
Cheers,
Mike
CYYZGUY
Hi Alan, can you check
C0271F / WJA593
Westjet
Always shows up as aircraft type PA14 beloning to a Sylvain Bourdon which is obviously not correct.  I have the latest database of course.....
Any ideas?
regards,
40" LED Monitor
40" LED Monitor
CarlosAbreu
13-09-2017 Updated file in attach.
Carlos
Cable: Ecoflex 10 (15m)
Station: XRange2 PGANRB501386
Antenna: Airnav Systems
Cable: LBC240 00220M (15m)
Hi Mike
By co-incidence I added the two UH-60's two days ago
Hi Jason
The database is correct C0271F,C-FOVE,582,Wag-Aero Sportsman 2+2,Sylvain Bourdon,,PA14
What is wrong here is the one of the WestJet fleet appears to be miscoded and is using the wrong code on at least one of its boxes.  I believe that it may be C-FUWS which should use C0371F as its code.   It may even be a corrupt packet but a look at your log would show if WJA593 was on twice at the same time showing both codes and establish this.
#12134
Morning Terry, thanks again.  Have added in AE5F16 as detailed also reported on Fighter Control
