0 Members and 25 Guests are viewing this topic.
Cheers x, probably the case
No worries, standardised now
Afternoon Alan,
With regard to reply #12983, the Spanish d/b gives the details :
EC-MSP Dornier Do-28G-92 Skyservant c/n 4331 registered August 2017 to Skydive Spain ex HA-VOC. This is from the partial Spanish register which does not show hex details. Strangely, the full pdf Spanish register which is correct from the 1st of November 2017 shows no details for this registration so , I guess, they are a bit behind Paul with their info.
Well you know the Spanish Ian, they will get to it sometime!!
Michel
Alan,
AFR53LQ LFLC-EHAM
EWG185 KMCO-EDDK
Michel
CarlosAbreu
27-11-2017 Update file in attach.
Carlos
Cable: Ecoflex 10 (15m)
Station: XRange2 PGANRB501386
Antenna: Airnav Systems
Cable: LBC240 00220M (15m)
Good morning Alan, Mondays unknowns:
MIL:
* 3F82D0  SHARK2                                                         2017/11/27 10:02:19
* 3F82D0  PIRAT2                                                         2017/11/27 13:37:56
* 3F82D0  PIRAT2                                                         2017/11/27 14:33:26
781250  DKH7955 https://xfw-spotter.blogspot.de/search/label/7955
Regards Ingo
Sunday: none, Saturday:
489883  PHGED
4D0205  SVW48ML no further information
Morning Ingo
781250,B-1003,7955,Airbus A321-231,Juneyao Airlines
489883,PH-GED,AT3-042,Aero AT-3R100,(Miscode hex of SP-GED) should use 4851F3
4D0205  SVW48ML noted 25th out of Luxembourg and I noted it last night over Japan, should be registered LX-MLO but no further information on it yet
Mil tac added
Just been advised that 4D0205 is the former OE-INC re-registered and is now
4D0205,LX-MLO,9168,Bombardier BD-700-1A11 Global 5000,Global Jet Luxembourg
Morning Terry, thanks again
X
* 1F1D5B        2017/11/28 12:00:20
151D5B decodes to RA-73051 so I believe 1F1D5B to be the ex factory hex for MC-21 No Prefix 73051
X
