0 Members and 16 Guests are viewing this topic.
Thanks again Terry
My d/b gives the Sami Ali etc and I will go with it.  Presumably the SA in the registration is Sami Ali
Morning Terry, thanks again
CarlosAbreu
15-12-2017 Updated file in attach.
Carlos
Cable: Ecoflex 10 (15m)
Station: XRange2 PGANRB501386
Antenna: Airnav Systems
Cable: LBC240 00220M (15m)
Good afternoon Alan, Fridays unknowns:
3D3245  DERHD https://www.ffg-braunschweig.de/verein/flotte possibly some other updates to the database can be done...
3E255E  DIFIS no news since yesterday
MIL: 3EBFB7  GAF063
461FA9  FIN8961 (was in my range before it was added. So no auto-populate. I read your post about OH-LZT)
470D40 BCS5572 again, but this time I can confirm that the entries are caused by bad packets received and not a(nother) miscoded aircraft. Therefore no action is needed from you, Alan.
88814F  VJC7998 another Airbus on delivery: https://xfw-spotter.blogspot.de/2017/12/a321-211sl-vietjet-air-d-avyv-vn-a637.html
C0788D  TSC90 seems that OK-TVY is re-reged back to C-GTQY and returning home http://www.airfleets.net/ficheapp/plane-b737ng-30724.htm https://www.radarbox24.com/data/mode-s/C0788D https://www.flightradar24.com/data/aircraft/c-gtqy#d46f5aa
Regards Ingo
CarlosAbreu
New aircraft for Azores Airlines (ex SATA Internacional)
Airbus A321-253N
c/n: 7972
ICAO24: 495266
Regist: CS-TSF
Delivery flight RZO9001 EDHI-LPPT 15-12-2017
Carlos
Thanks Carlos
CS-TSF was added to the database 7/12
#13281
Carlos,
the aircraft is in the db as it has populated to my local database. If you are running the ANRB.exe software I would recommend a manual populate session via MyLog database explorer. Please keep in mind, that it is necessary to set the "From Date" to december 15th followed by a click on filter button to get the plane populated during the manual populate run.
Edit: Alan was faster.
@Alan: Ah, that explains why it was auto-populated...
Regards Ingo
Afternoon Ingo
3D3245,D-ERHD,,Cirrus SR22,FFG e V Braunschweig,
Nothing yet on D-EFIS
Mil tac added
88814F,VN-A637,7998,Airbus A321-211,VietJetAir also out of XFW on delivery so in your coverage before it was added
C0788D,C-GTQY,30724/2286,Boeing 737-8Q8,Air Transat, on winter lease like a number of others  to Air Transat and Sunwings
Afternoon Terry
Regarding the Twin Otters my d/b, Joe Baugher and http://twinotterarchive.com/DHC-6_852.html http://twinotterarchive.com/DHC-6_862.html and  http://twinotterarchive.com/DHC-6_863.html give them as 08 fiscal year.  You will note that the final photo on each of the links give the aircraft in Golden Knight colours has the serial as 80262, 80263 and 80264
Regarding OY-PSA, you have me confused as you state that it is not with Jet2 but then go on to state that the end of the lease is in 2 weeks time?
5Y-JKC, I will stick to 5Y-JXC Skyliner gives it as that as well, typo??
Afternoon Alan,
PRI9534 : GCRR-LERS
SXD4946 : GMAD-EDDF
DAH1078 : DAOO-LFQQ
Local amendments :
c/n 2318 A319 Ei-GAU of Volotea has been reregistered as EC-MTD. New hex unknown.
c/n 22183/32 B757 G-BIKL of DHL has been permanently retired at Madrid.
c/n 27992/523 B737 EI-IAS of Alba Star has been reregistered as EC-MTV. New hex unknown.
c/n 32920/1293 B737 OM-NAS is still operating as such with Alba Star. It has not been reregistered to EC-MTV that is c/n 27992/523 above.
CarlosAbreu
Thanks, since a while I'm manually introducing data in database and CS-TSF wasn't detected yet by my antenna, aircraft info was sent by a friend.
Carlos
Eveing Ian
EC-MTD is in the databse with it hex of 3455D8
EC-MTV is in the databse with its hex of 345617
OM-NAS added to d/b as 503DD3
No problem Carlos, thanks anyway
#13288
Terry,
I understand what you are saying but why would they have the 8 starting the serial if it is not 08- fiscal code as with out the 08 fiscal year there is no 8 in the serial.  The example you give is straight forward as no fiscal year showing.   I also note Joe Baughers comment that it may possibly be 10- fiscal year for them and the second shot gives that info carried forward just in case without deleting the 08 details, covering all bases so that one of them must be correct.
Those 3 didn't come off the production line until 2012.  It is important to recognize that the serial number reflects the Fiscal Year in which the order for the aircraft is placed, not the year in which it is delivered.
I am happy to stick with what I have and you can go your own way
