0 Members and 22 Guests are viewing this topic.
400M23R
345696 had ECLOI  in the callsign this would if correct make if an R44 c/n 12927 this has been miscoding as 4061C6
Kind regards
Graham
#14371
Thanks Graham, its easy with the registration :-))  Whereabouts are you located?
Evening Ingo
3918D7 decodes to F-GGGX which as a DR40 broken up a number of years ago, no idea on what may be using it now
Mil tac added as WERE the other two on departure from XFW
400M23R
I'm based at Manchester Airport
Graham
400M23R
3918D7 maybe a corruption of 3918D3 F-GGGT , this was using the callsign DTR3V according to planefinder
https://planefinder.net/flight/DTR3V/time/2018-02-15T16:15:00
Kind regards
Graham
paul tricker
880861  HSBCA                                                          2018/03/23 07:34:25
HS-BCA  C172S  172S10256  Bangkok Aviation Services
& two vehicles at BKK you probably cannot do anything with!
   ADF002  FOLLOW02                                                       2018/03/23 00:00:00
   ADF009  FIRE09                                                              2018/03/23 00:00:00
paul
ffa1978
Many thanks Graham!
I had F-GGGT in my list, but with flight id DTR2V.
Good morning Alan, Fridays unknowns:
MILs:
* 3E9812  STASH2                                                         2018/03/23 09:33:20
* 3F5285  BULL2                                                          2018/03/23 09:27:35
* 3F5880  SMASH1                                                         2018/03/23 08:41:09
47BFC8  DOC01 https://flightaware.com/live/flight/DOC1
Regards Ingo
CarlosAbreu
23-03-2018 Updated file in attach.
Carlos
Cable: Ecoflex 10 (15m)
Station: XRange2 PGANRB501386
Antenna: Airnav Systems
Cable: LBC240 00220M (15m)
Thanks Grham,
Looks like a corrupt packet at work there for Ingo
Thanks again Paul.  I have added in those two vehicles as  their hex codes are not in use at this time.
Afternoon Ingo.  Mil tac added but nothing on the chopper yet.  Caught it first yesterday morning on the first leg of its journey but no details on it yet
Nothing  yet on 43EC23 ffa
