0 Members and 82 Guests are viewing this topic.
#14550
Unfortunately it is correct FFA as per the Czech register 49D2D3 is 49D2D3,OK-DSQ,5577,Aerospatiale AS355 N Ecureuil 2,DSA, http://portal.caa.cz/web_redir?aparameters=aid_nast:282&aparameters=id:1316907&aparameters=kategorie_letadla:&aparameters=typ_letadla:&aparameters=vyrobce_id:&aparameters=vlastnik:&aparameters=provozovatel:&aparameters=rejstrikova_znacka:DSQ&aparameters=vlastnik_ico:&aparameters=provozovatel_ico:&aparameters=ico:&aparameters=dic:&aparameters=jmeno:&aparameters=prijmeni:&aparameters=dat_nar:
An unfortunate consequence of transponders not being recoded when sold as all codes beginning 49D*** are Czech codes and while the correct use is not allocated we can get away with miscode but when  the correct users is allocated we show it.  RA-67031 should be 1505D7,RA-67031,2815,Let L-410UVP-E20,Orenburzhye
The other codes shown are also in use by Czech aircraft apart from 49D34C which is unallocated at this time
ffa1978
#14551
Yes.it used hex of factory.Its true RA and 1XXX .Many l410 in Russia used factory hex.In my town about 30 DA-42 and DA-40 with austrian factory hex (and some hex for 2-3 aircraft) :(
It happens all over ffa
Afternoon Alan,
WOW1WA : LEAL-BIKF
VLG1343 : LFRS-LEAL
TVS1836 : LLBG-GCTS
TVS1837 : GCTS-LLBG
Afternoon Ian, thanks again
Michel
Alan,
BEE2JH EGNM-EDDL
BEE4DB EGLC-EDDL
BMR9LU EGGD-EDDH
DLH8RX EDDF-EHAM
KLM1460 LFRS-EHAM
Michel
CarlosAbreu
04-04-2018 Updated file in attach.
Carlos
Cable: Ecoflex 10 (15m)
Station: XRange2 PGANRB501386
Antenna: Airnav Systems
Cable: LBC240 00220M (15m)
Good morning Alan, Wednesdays unknowns:
3FF66B  DMUGX (2x) no further information
KLM1981 KL1981 EHAM LHBP
Regards Ingo
M
SAS1786   EKCH   EETN
SAS51T   ESSA   EETN
FIN1961   EFHK   OMDB
FIN8ZE   EFHK   EVRA
FIN639   EFHK   EFKT   via EFIV
4677E7  Ground Transmitter
4677ED  Ground Transmitter
Morning Ingo
I don't have anything on it either
Afternoon Alan,
BGH2002 : GMMX-LBSF
BGH2001 : LBSF-GMMX
Not populating :
4CACD0 FL390  No further details.
Afternoon Ian
Its showing as EI-GFF on the network so that makes it 4CACD0,EC-MTU,469,Airbus A330-223,Wamos Air using  it old details.  Went out to Ibiza and back to Madrid so looks like a flight test
