0 Members and 30 Guests are viewing this topic.
Good morning Alan, Saturdays unknowns:
3C07DA  DCS403 all I found https://flightaware.com/live/flight/DCS403
3E5C91  DKAGF https://fliegerclub-nordhausen.com/flotte https://www.planepictures.net/v3/show.php?id=867781
3E6F11  DKHGJ (2x) http://alles-mit-links.ch/Wordpress/?page_id=394&temp100=K&kennzeichenland=D
3FF568  DMBJO (2x) again, no change = no details found
3FF656  DMSJG (2x) no further information
Regards Ingo
Morning Carlos, thanks again
Morning Ingo
3E5C91,D-KAGF,44658,Scheibe SF 25 C Falke
3E6F11,D-KHGJ,31171,Schleicher ASH-31Mi  caught a lot of new gliders yesterday
Still nothing on the unknows
Northern Watch
Good morning Alan
Just carried out an update and D-IKOB was not present. Strange anomaly and begs the question how many others are lurking in my database.
Best regards
Keith
Morning Alan,
BUC8623 : LICC-LEMD
TOM17B : LEAL-EGNT
AAF242 : DAON-LFPO
JAF1YV : EHEH-GMMW
EXS6BK : LEAL-EGNT
SAS4673 : ENGM-LEAL
SAS4674 : LEAL-ENGM
LZB485A : LBSF-LEBL-LEMG-LBSF  Note that this is shown on the arrivals/departures boards as just LZB485.
Afternoon Keith, it may be due to the update method you use, I would suggest that you use the Update all records option if you don't already do that
Afternoon Ian, thanks again
#14752
Evening Alan,
PRW2875 : EGSS-LEAL
GMI1070 : LHBP-LEAM
VLG4306 : LEAL-LEBL
OLY728 : LSZH-GCFV
OLY729 : GCFV-GCTS
OLY747 : GCTS-EDDK
Just landed at Alicante with hex of 43E9CD a G650 c/n 6047. It is showing the flight id as MATAK (presumably M-ATAK) but the registration is given as M-KSOI. These details are in the d/b.
43E9CD is M-ATAK, its previous registration was M-KSOI.  M-KSOI was deleted from the database on 16/02/2018 and the registration was amended to M-ATAK at the same time 11:21:56 on that date
I have checked my Navdata and can confirm it does not have an entry against M-KSOI but has an entry for M-ATAK, see attached for details.
I can only presume that you do not use the Update all records option when updating the database.  This option downloads the database directly from the server and incorporated all additions, deletions and amendments made since the last update users make.  The other option does not and in my mind should not be used unless users want to keep previous records.
It may also be because you have not downloaded a new database because of the issue I advised of previously which took place on 15/2
Cheers Alan.
I do my weekly updating tomorrow and will use the update all records option as suggested. If it all goes wrong I will call upon your assistance when you come over here. Be afraid, be very afraid !
Even you cant go wrong Ian.  Also be advised the database will have the issue corrected tomorrow so you may want to hold off until I let you know
CarlosAbreu
23-04-2018 Updated file in attach.
Note: It seems that CS-TTW E195 from TAP appears in database photo link with an A319 image, please confirm.
Carlos
Cable: Ecoflex 10 (15m)
Station: XRange2 PGANRB501386
Antenna: Airnav Systems
Cable: LBC240 00220M (15m)
Hi Carlos
As far as I can see these are the 2 photos allocated for CS-TTW
https://www.airteamimages.com/embraer-erj-195_CS-TTW_tap-express_293247.html
https://www.airteamimages.com/embraer-erj-195_CS-TTW_tap-express_285743.html
Check and if need be delete any wrong photo for CS-TTW from your photo folder
X
Alan/ffa
New Russian unknown.... looks like a chopper flying in tight circles around NE MOW c/s 1
* 123450        2018/04/23 12:11:12
X
