1 Member and 39 Guests are viewing this topic.
Aahhh De Havilland!!, thanks Paul
CarlosAbreu
07-05-2018 Updated file in attach.
Carlos
Cable: Ecoflex 10 (15m)
Station: XRange2 PGANRB501386
Antenna: Airnav Systems
Cable: LBC240 00220M (15m)
Good morning Alan, Mondays unknowns:
MILs:
* 3E8221  GAF168                                                         2018/05/07 08:21:26
* 3E85D8        2018/05/07 08:07:43
* 3E85D8        2018/05/07 09:05:01
* 3E85D8        2018/05/07 13:27:33
* 3E85D8  GATOR1                                                         2018/05/07 14:28:13
* 3E8973        2018/05/07 08:55:02
* 3EAF41        2018/05/07 11:39:27
   3EAF45  HG01B                                                          2018/05/07 11:24:39
* 3EB4C0  JUDGE2                                                         2018/05/07 07:07:00
* 3EB4C0  SNIPER4                                                        2018/05/07 11:47:56
* 3F5EE3        2018/05/07 08:02:15
* 3F5EE3        2018/05/07 08:36:47
* 3F73B3        2018/05/07 07:49:34
* 3F73B3  SNIPR3                                                         2018/05/07 11:51:55
3FF620  DMBSR  https://abpic.co.uk/pictures/registration/D-MBSR already posted, please check if it is in the db correctly Thanks!
Regards Ingo
Morning Ingo
3FF620 D-MBSR is in correctly and was added in at 1643 yesterday so if you carried out your update before that it would not be included
Mil tac added in
reception was before it was added to the darabase, that's why it didn't auto-populate.
Thanks!
Good to know it wasn't me Ingo
X
#14932
Two unknowns over MOW today, possibly one Philippine A320 delivery RP-C4114?
* 511081        2018/05/08 19:35:34
* 758533        2018/05/08 14:37:56
X
X
#14933
This is a new one on me..... I have CSN6001 B-7996 B738 on landing at SVO but taking off as CSN6002 B-8637 A20N!!! Wrong code in one box??? It should be a B738 flight and might cause a little confusion for Chinese spotters.
78102C  CSN6001  ZGGG-ZWWW-UUEE  B-7996     B738  China Southern Ai... 2018/05/08 19:00:25
78102E  CSN6002  UUEE-ZWWW-ZGGG  B-8637     A20N  China Southern Ai... 2018/05/08 21:39:41
X
Hi X
758533 is RP-C4114 using registration as flight ID, don't know why you didn't receive the flight ID
511081 was used by ES-TLO Aero L-39C c/n 530512 which is now RA-1909G so presumably it is using its former hex code
Presumably either a miscode on one box or a corrupt packet for the CSN flight
X
B-8637 is not corrupt still pinging as such and has since taxiing!
Only got a few pings on the Philippine so might not have picked up the reg as it was at max distance for my box
PS I have problems downloading updated DB as it keeps timing out, the 102 kb db is causing me some  issues out here
X
I can only presume it is miscoding then X,  either that or it was wrong in the way in or there has been an aircraft change on the ground, you tell me.  Its also showing the same hex on FR24.  Both sites can only decode the hex code the aircraft is sending out
If you want a smaller download, download only the aircraft table and that will make it smaller
X
Tried aircraft only and same result!
I am 100% certain it is the B738 double coding as I saw it land in the light as a B738, and take off in the dark and it did not strobe like an A20N and B-8637 never landed at SVO...A definite miscode on take off which will no doubt cause confusion!
X
CarlosAbreu
08-05-2018 Update file in attach.
Carlos
