0 Members and 15 Guests are viewing this topic.
Good evening Alan, Tuesdays unknowns:
MIL: 3EBEB6  NITRO2
3FEBFE  DMNBR https://www.planepictures.net/v3/show_en.php?id=1457026
3FF2D6  DMMSE still no luck with the details
3FF56C  DMEAX (2x) it's the same with this one
4409C3  OEDLV https://www.austrocontrol.at/jart/prj3/austro_control/main.jart?content-id=1334334955514&rel=de
Regards Ingo
#15286
Evening Ingo
Mil tac added
3FEBFE,D-MNBR,,Breezer Aircraft Breezer B400
4409C3,OE-DLV,24-1082,Mooney M20J 201,GEOHAWK,,M20P
Still nothing from me either on the other two
CarlosAbreu
12 & 13-06-2018 Updated file in attach.
Carlos
Cable: Ecoflex 10 (15m)
Station: XRange2 PGANRB501386
Antenna: Airnav Systems
Cable: LBC240 00220M (15m)
Hi Carlos
I am assuming that TVP91YP should read TVF91YP given the departure point
CarlosAbreu
Yes, is TVF91YP  sorry for typing error.
Carlos
No problem Carlos, just wanted to make sure
Good afternoon/evening Alan, Wednesdays unknowns:
391D9C  FJSFE no luck with the details
   3C6420  CFG9MH   LGIR-EDDH                                             2018/06/13 04:45:49
   3C6420        2018/06/13 13:46:42
   3C6420  CFG6ZW                                                         2018/06/13 19:03:27
at the same time i got 3C6424 with the same flight id's in my list. For each time window of 3C6420 there is a 3C6424 entry. In my opinion al little too many simultanous entries for bad packets received.
MILs:
* 3E8ED5  GAF327                                                         2018/06/13 08:01:30
* 3EAE21  SHOCK41                                                        2018/06/13 12:57:24
   3EBEB6  JUSTIS                                                         2018/06/13 08:17:09
   3EBEB6  JUSTIS                                                         2018/06/13 15:22:25
3FF021  DMSGI https://www.planepictures.net/v3/show.php?id=1400523
3FF2D6  DMMSE nothing new to report
3FF4E9  DMHCY same with that one
3FF53A  DMFLC  http://www.airnieuws.nl/movements/seppe/jul17/index.html
3FF680  DMAXF still no luck with the details
ABB22F  N66DD http://registry.faa.gov/aircraftinquiry/NNum_Results.aspx?NNumbertxt=N66DD
Regards Ingo
Evening Ingo
Mil tac added
3C6420 is not allocated, doesn't decode so guess it is also being given off as a false squit
3FF021,D-MSGI,0303-6514,Ikarus C42B
Added 3FF53A,D-MFLC,,Magni M24 Orion, although my d/b shows that c/n 24-17-0684 became PH-4Q8 last July
ABB22F  N66DD I guess it is miscoding as it is allocated A8B22F
Nothing on the others
X
Which is this one M-FAAF or M-ORAT?
* 43EAEF  MFAAF                    M-ORAT     FA7X  Swift New Jet Lim... 2018/06/14 19:58:53
X
Its been re-registered X, now M-FAAF
Thanks Alan
X
#15297
Today's unknowns so far
* 4243B2        2018/06/15 13:14:54
* 7DF2FF  GABLESEN                                                       2018/06/15 13:42:38
GABLESEN I have picked up before on a variety of types and operators e.g. SilkWay An12, Kosmos Tu134 and Pakistan Air Force Gulfstream so no idea
But this one BELOW had me confused, flying circles over me at 1000-1400FT showing as a F900...it was in fact a dark grey police survellience chopper equipped with video camera but just could not read of reg! so another miscoder! Possibly RF-29010 Aerospatiale 355N Ecureuil 2 5567 also at one time N54HG now operated by АОСН ГУВД Москвы (AOSN GUVD Moscow).
   A6D649                           N54HG      F900  Starrflite Falcon... 2018/06/15 14:11:19
X
No idea on your unknowns
Yes the AS55 was N54HG c/n 5567 at one time before being removed from the FAA list in April 2016 and as you state it became RF-29010.  You may consider it appropriate for you to update your local database to reflect this but I intend to leave the server database as is.
X
ffa
This was picked up flying in and out of Zhukovsky today at up to 32000Fft for over one hour....have you any idea?
* 7DF2FF  GABLESEN                                                       2018/06/15 14:42:31
GABLESEN c/s I have picked up before on a variety of types and operators over the years e.g. Silk Way An12, Kosmos Tu134 and Pakistan Air Force Gulfstream so that is no help.
X
