0 Members and 39 Guests are viewing this topic.
M
FIN9TJ   ENTC   EFHK
FIN4BT   EFHK   ENTC
FIN2PE   EFHK   EETN
FIN7M   EETN   EFHK
FIN881   EFHK   ESSV
FIN882   ESSV   EFHK
FIN7BF   EFHK   LOWI
FIN5YF   LIPR   EFHK
FIN735   EFHK   UMMS
FIN736   UMMS   EFHK
FIN9EA   EFHK   LIRN
FIN1943   EFHK   LTAI
FIN1944   LTAI   EFHK
FIN958   EKCH   EFHK
FIN68A   EFHK   LIPZ
FIN5LP   LIPZ   EFHK
FIN2SE   EFHK   EYVI
FIN7LQ   EYVI   EFHK
FIN72D   EFHK   LKPR
FIN4TE   LKPR   EFHK
FIN7FF   EFHK   LIRP
FIN6HU   LIRP   EFHK
FIN27Q   EFHK   LDPL
FIN5EZ   LDPL   EFHK
FIN5BZ   EFHK   EKCH
FIN9W   EFHK   LFMN
FIN5K   LFMN   EFHK
FIN9WT   LGSA   EFOU
GLP613   UUDD   BIKF
GLP614   BIKF   UUDD
SBI3093   ULLI   ESSA
SBI3094   ESSA   ULLI
AUL540   UMKK   ULLI
KTK7891   ULLI   LTAI
KTK7893   ULLI   LTAI
CTN2801   ESPA   LDSP
LLC28FT   ESNU   LGRP
LLC325R   LGRP   EFHK
LLC26XL   EFHK   LGRP
PGT4TW   LTAC   ESSA
PGT4GA   ESSA   LTAC
BGH5031   LBBG   ESPA
BRX1102   ESNN   ESGG
BRX1103   ESGG   ESNN
JTG933   EFHK   LGIR
JTG934   LGIR   EFHK
VKG1343   LBBG   EFHK
BLX169   EFHK   LEMH
BLX170   LEMH   EFHK
KTK5191   ULMM   LTAI
KTK5192   LTAI   ULMM
IBK9012   EFOU   LGSA
IBK9013   LGSA   EFOU
IBK486   EFHK   LDDU
IBK487   LDDU   EFHK
LOT8251   EETN   LWOH
LOT8252   LWOH   EETN
MYX353   EETN   LEMD
MYX354   LEMD   EETN
NPT3848   EKCH   EFHK
NPT3849   EFHK   EKCH
DTR131   EFMA   ESSA
DTR132   ESSA   EFMA
DTR133   EFMA   ESSA
DTR134   ESSA   EFMA
DTR137   EFMA   ESSA
DTR138   ESSA   EFMA
FIN803   EFHK   ENBR   via ESSA
FIN9TM   ENBR   EFHK   via ESSA
CLU928   VHHH   EGSS   via UNKL
4A9312 , SE-DXR , SB35 , Saab J-35J Draken , Swedish Air Force Historic Flight , 35556
Miscode (allocated A519B2):
A51982 , N428DR , F900 , Dassault Falcon 900EX EASy , Maverick Air II , 154
X
You may have already entered this China Southern delivery on departure B-1089 Airbus A321-271N 7968
* 7813B4  CSN1089                                                        2018/06/20 15:34:10
X
Terry
Yes the hex codes for D-AIX* registrations follow in sequence like you would expect.  3C6710 decodes to D-AIXP therefore as it is being carried by D-AIXJ makes it a miscode.  As can be seen from the following D-AIXI is 3C6709, D-AIXJ should therefore be using 3C670A not 3C6710.
A follows 9 then B, C, D, E, F, before it gets to 3C6710 which decodes to D-AIXP, I have therefore also got it in the database with its correct code for when it is recoded to its correct allocation.  D-AIXK and D-AIXL are also included as they are due for delivery soon.
The fact that others state something is correct does not make it correct.
3C6701,D-AIXA,074,Airbus A350-941,Lufthansa,DLH,A359
3C6702,D-AIXB,080,Airbus A350-941,Lufthansa,DLH,A359
3C6703,D-AIXC,087,Airbus A350-941,Lufthansa,DLH,A359
3C6704,D-AIXD,127,Airbus A350-941,Lufthansa,DLH,A359
3C6705,D-AIXE,136,Airbus A350-941,Lufthansa,DLH,A359
3C6706,D-AIXF,146,Airbus A350-941,Lufthansa,DLH,A359
3C6707,D-AIXG,174,Airbus A350-941,Lufthansa,DLH,A359
3C6708,D-AIXH,184,Airbus A350-941,Lufthansa,DLH,A359
3C6709,D-AIXI,202,Airbus A350-941,Lufthansa,DLH,A359
3C6710,D-AIXJ,209,Airbus A350-941,Lufthansa (Miscode),DLH,A359
3C670A,D-AIXJ,209,Airbus A350-941,Lufthansa,DLH,A359
3C670B,D-AIXK,212,Airbus A350-941,Lufthansa,DLH,A359
3C670C,D-AIXL,255,Airbus A350-941,Lufthansa,DLH,A359
Many thanks M, much appreciated
X
Correct, it is  7813B4,B-1089,7968,Airbus A321-271N,China Southern Airlines
X
I am used to miscoder's but this aircraft miscoded several times over some time, only 4K-AZ85 was airborne...atmospherics again at play perhaps, but was damned consistent as I knocked it out four times and it kept coming back!
* 600815        2018/06/21 00:23:25
   600855  AHY5202            4K-AZ85    A345  Azerbaijan Airlines  2018/06/21 00:13:41
X
CarlosAbreu
21-06-2018 Updated file in attach.
Carlos
Cable: Ecoflex 10 (15m)
Station: XRange2 PGANRB501386
Antenna: Airnav Systems
Cable: LBC240 00220M (15m)
Good morning Alan, Wednesdays unknowns:
39483C  FJWUS (2x)  http://www.airnieuws.nl/movements/texel/mei17/index.html
3E6C82  DKGHI (3x) https://www.onlinecontest.org/olc-3.0/gliding/flightinfo.html?dsId=5371704  https://www.gliderradar.com/details/main/sid/4346
MIL:
  3F519D        2018/06/20 07:53:14
   3F519D  TORO3                                                          2018/06/20 08:53:28
3FF2DD  DMMDP no further information
3FF4E9  DMHCY  nothing new to report
3FF516  DMWJS (2x)  https://www.flickr.com/photos/pilot_michael/38358332301/ many thanks to ikarus for writing the type on the wingtips...
WZZ358  W61706 LEBL EPGD
4B1805  SWR5201 https://www.planespotters.net/airframe/Bombardier/BD-500-CSeries/HB-JCN-Swiss/D8MOU3br
Regards Ingo
M
FIN7RD   LEPA   EFOU
FIN68N   EFOU   LEPA
FIN5KN   EFHK   LFMN
FIN7AB   LFMN   EFHK
JTG921   EFHK   LYTV
JTG922   LYTV   EFHK
RWZ9239   ULLI   LIPR
RWZ9240   LIPR   ULLI
Yes X, once you have a decode error on screen I wont go until the aircraft leaves your coverage
Morning Ingo
39483C,54AKF,,B&F Funk FK-9 Mk.V,(F-JWUS),
3E6C82,D-KGHI,21827,Schleicher ASK-21Mi
Mil tac added
Nothing on your unknowns
Route added
4B1805,HB-JCN,55032,Bombardier BD-500-1A11 CS300,Swiss Global Air Lines
Carlos
Do you have any information on CS-UUD please
