0 Members and 45 Guests are viewing this topic.
#1545
Many thanks X, c/n 5375
Good Afternoon Alan, unknowns from Wednesday:
40017C once was VP-BWQ but this one was re-registered couple of years ago, nothing about a new one
4A066A nothing more
4A81B9 nothing more
894081  BAH11 http://www.flightradar24.com/data/airplanes/a9c-isa/
F57187 no country allocation
MILs:
   3E8667  GAF910                                                         2015/07/08 10:11:57
   3E8667  GAF910                                                         2015/07/08 13:01:55
* 3EB076  GAF640                                                         2015/07/08 06:44:31
* 3EB076  GAF640                                                         2015/07/08 13:25:16
   3F7D22  NITRO3                                                         2015/07/08 13:13:15
   3F9643  MISTY                                                          2015/07/08 12:48:31
* 3F9E98  COLT                                                           2015/07/08 09:01:43
* 3FB7B2  PACK11                                                         2015/07/08 07:19:58
That's all from yesterday...
Hi Ingo,
Only one I can ID is 894081 A9C-ISA B738 as per reply 1529
Mil tac added.
Evening Alan,
Just the one.
NAX5536 : LEAL-ESGG
Cheers Ian, evening to you
AoD
Hi Alan
ADR52M    EPLL - EDDM
AFR1044    LFPG - UUEE
ANA217    RJTT - EDDM
AZA544    LIRP - EDDT
AZI846    LLBG - EDDB
AZI847    EDDB - LLBG
BER1055    LKPR - EDDF
BER154F    EDDL - LKPR
BMS2931    LRBC - EGGW
BMS2932    EGGW - LRBC
CAI4341    LTAI - EDDH
CAI4342    EDDH - LTAI
CFG2PE    EDDB - LGRP
CFG2TM    LGRP - EDDB
CPA383    VHHH - LSZH
DTR86    EKBI - LGSA
EXS154    LKPR - EGPF
GMI2059    LGSR - EDDH
GWI5561    LTFH - EDDT
GWI65C    EDDH - LOWW
GWI91L    LDPL - EDDH
KKK184    EDDF - LTAF
TAP1305    LKPR - LPPT
TFL268    LGKO - EHAM
TRA1330    LBBG - EBBR
TRA194C    LGKO - EHAM
TRA736    LTFE - EHAM
TVS8NH    LFPG - LKMT
TWI147    LTAI - LKPR
VIM451    LBBG - EDDC
VLG7001    UUEE - LEBL
and unknown: 49D0FF
M
FIN859   EFHK   LSZH
FIN860   LSZH   EFHK
FIN886   LFMN   EFHK
PRI613   ESSA   LTAI
PRI614   LTAI   ESSA
Many thanks AoD
49D0FF,OK-PSY,32R-7680073,Piper PA-32R-300 Lance,Letecké akrobatické centrum CR
Blueboy
Hi Alan, picking-up hex A4C9C5 - which decodes as N40753 - a Cessna test registration - Flight ID is IMCAM
J.D
Hi JD,
I-MCAM is a Citation M2 c/n 525-0874, LOOKS LIKE IT IS ON DELIVERY AND STILL USING ITS PREVIOSU HEX.
X
two new Indian unknowns, 80032F I believe to be KW-3554 Indian Air Force ERJ
* 80032F        2015/07/10 16:23:05
* 800B44        2015/07/10 23:08:43
X
X
And off we go again
FDB7701  OMDB-OEJN                A6-FDF     B738  flydubai             2015/07/10 14:49:13
FDB7702  OEJN-OMDB                A6-FDF     B738  flydubai             2015/07/10
FDB7923  OMDB-OEJN                A6-FEH     B738  flydubai             2015/07/10 21:43:05
FDB7924  OEJN-OMDB
X
Hi X,
80032F is KW3554 and is in the d/b
Nothing on 800B44
The routes have been added in and again went a wee bit in advance for each sequence.
Many thanks
CYYZGUY
#1559
Back from Vacation all....
TSC898
No Routing
https://flightaware.com/live/flight/TSC898
Also a flight missing info.
C072A7  Flight ID CGRKW
No Other info populating.
regards,
Jason
40" LED Monitor
40" LED Monitor
