0 Members and 34 Guests are viewing this topic.
Evening Alan, while watching TV about the heat in Germany:
along with 3D140D D-EFVP C206 Florian Flugdienst the following C206: 3D275C  DENDS  C206 D-ENDS is also operated by Florian Flugdienst
Regards Ingo
Good evening Ingo, nice to hear from you stranger.
I have changed the operator for both those aircraft
Unfortunately I fear, that there won't be much more activity by me during next couple of month.
Some more information about the two C206:
D-EFVP operates as Florian Flugdienst 2 and D-ENDS operates as Florian Flugdienst 1. They use Florian Flugdienst 1&2 during radio comunication during operation (as far as I was able to optain from the TV documentation).
The operator for both aircraft is Feuerwehr-Flugdienst Niedersachsen of Landesfeuerwehrverband Niedersachsen e. V. (LFV-NDS). As this is way too long to put it in the operator field, I would suggest to use the following as operator: LFV-NDS Feuerwehr-Flugdienst Niedersachsen
My apologies for the additional work. But that way the database should be as correct as possible.
Thanks Ingo, watch and not burn yourself out
Evening Terry, many thanks
CarlosAbreu
13-08-2018 Updated file in attach.
Carlos
Cable: Ecoflex 10 (15m)
Station: XRange2 PGANRB501386
Antenna: Airnav Systems
Cable: LBC240 00220M (15m)
X
   180AE5  RA2789G                                                        2018/08/14 15:22:58
should be RA-2789G C152 Cessna 152 c/n 15279579
X
Afternoon Alan,
NAX2VJ : LEAL-ESSA
RYR90ZW : LEAL-ESKN
DAH1231 : LFPG-DAAG
FOO1071 : LEAL-LOWW  1st flight noted using a  Vueling Austria flight id. OE-LCF.
Afternoon Ian, thanks again
Kenny
New route for Air Mauritius
MAU642  FIMP VTBS via WSSS
MAU643  VTBS FIMP via WSSS
ANRB 3km north of VTBD
Pleased be advised that the database updater facility is offline at the moment due to a server migration and will hopefully be back online later
X
Not sure what is going on with this aircraft, but flying from ZIA to SVO with c/s OKJPT, DB has it as A6-FDH, but showing as OK-TSP on FR24
  49D37F  OKJPT                    A6-FDH     B738  flydubai (Miscode... 2018/08/15 15:48:11
X
