0 Members and 76 Guests are viewing this topic.
Evening Terry, thanks again
Thanks for the clarification X, it was your statement " These Sukhoi test regs should be in db as VARIOUS" that left me confused as to whether you were stating the registrations should be in as VARIOUS.
781587,B-304E,8462,Airbus A320-214,Air China
CarlosAbreu
20-10-2018 Updated file in attach.
Carlos
Cable: Ecoflex 10 (15m)
Station: XRange2 PGANRB501386
Antenna: Airnav Systems
Cable: LBC240 00220M (15m)
X
Alan/ffa
New Russian hex which ought to be RA-02103 (from 140837) at around 600ft but can find nothing on it
* 180837        2018/10/21 10:48:28
X
Nothing on that hex or registration X
Afternoon Alan,
Not populating : 3452D5  No further info.
French AF A340 registration '075' accompanying photo shows a UAE Apache registered '075'
No idea on your unknown Ian
Hopefully blocked the photo and you will be required to delete it from your photo folder
ffa1978
#16164
Quote from: X on October 20, 2018, 10:09:35 AM
PS However yesterdays 197AF1 throws a spanner in the works :) if it is 97009 as it should be 1F7AF1!
X
197AF1  95173 (Factory number) Suhkoi SuperJet 100-95B Severstal Aviacompany .LX code -code for experimental aviation not only Sukhoy.
180837 RA-2103G (Tecnam P-2002H Sierra)  ChelAvia
http://www.planesphotos.net/details.php?image_id=15674&sessionid=115ff58b8e4d4a98a2b09d1e4b7e7296&l=russian
X
ffa
Thanks I forgot about the Letter G at the end of registration replacing the 0 at the start of the registration in some instances
X
CarlosAbreu
21-10-2018 Updated file in attach.
Carlos
ffa1978
Quote from: X on October 21, 2018, 08:58:20 PM
ffa
X
This site correctly calculating registration from hex for aircraft with G at the end. http://demo.rzrbld.ru/
X
ffa
большое спасибо
X
