0 Members and 27 Guests are viewing this topic.
Afternoon Alan,
AEA60GF : LEPA-LEAL
VLG3447 : LEMD-LEIB
LMU1340 : HECA-LEMD
AFL2621 : LEMG-UUEE
VLG2021 : LEGR-LEBL
AAF260 : DAAG-LFPO
Afternoon Ian, thanks again
CarlosAbreu
#16262
05-11-2018 Updated file in attach.
Carlos
Cable: Ecoflex 10 (15m)
Station: XRange2 PGANRB501386
Antenna: Airnav Systems
Cable: LBC240 00220M (15m)
X
#16263
This hex should be in db as various OR used by both RA-01674 Agusta Westland AW109SP Grand New c/n 22333 and NAF-570 as the two ping the same ex Italian code for I-EASP.
  300324  RA01674                  NAF-570    A109  Nigeria - Air Force  2018/11/06 10:53:18
X
diddyboy
Hi Alan
An unknown Manx around Ystalyfera this Morning.
* 43EBE4        2018/11/06 08:15:18
Neil
Now that you have advised me that their is another A109 using the same hex I have done just that X
Neil
43EBE4,2-ESKB,23707/1388,Boeing 737-375(F),European Aviation out of Hurn on delivery somewhere and added when it came over me earlier
#16268
Morning Alan,
JAF72D : EHEH-GMMW
TOM1KY : LEAL-EGNX
EZY57AX : LEAL-EGPH
Thomson/TUI flights need to be double-checked as, once again, there appear to be discrepancies and difficulties in tying up. The departures board shows no flights to Glasgow on a Tuesday which may be correct now that the winter schedules are in effect or it may be that it operates fortnightly only in the winter. As I say, confirmation is required.
Edit:
Alan, the Tuesday flight does apparently go in the Winter. I have just checked the TUI winter timetable and it leaves Glasgow at 06.15 arriving in Alicante at 10.20 (Spanish time). I just wasn't up in time in order to check it. The TUI timetable is a good source of information on timings and routes .
Flight id's are given the further in you go if actually booking although unfortunately not the alphanumeric id's.
https://www.tui.co.uk/flight/
Hi Ian
I use the winter schedules provided by TUI for the TOM and TUI flights in the database  I only use the IACO/IATA flight ID's and the origin/destination and have no use for the days of operation which actually states days 1234567 for every TOM flight
The flights from Glasgow for the winter season are
TOM8KP,TOM1222,EGPF,LEAL,,
TOM5AC,TOM1223,LEAL,EGPF,,
TOM70D,TOM1632,EGPF,LEAL,,
TOM5PK,TOM1633,LEAL,EGPF,,
I did however note an defect on the txt file I used to send the bulk data to the server and that may have stopped some of the flights loading so I have loaded all the TOM flights back onto the server
Michel
Alan,
ACP2601 HKJK-EGCN
BEE4PD EGBB-EDDL
BEL2250 EKBI-EBBR
BMS3RL EGGP-LROP
CFG2DK EDDH-GCRR
DLH984 EDDF-EIDW
EWG9346 EDDL-EGCC
EZY41EJ EHAM-LEAL
EZY68NR EGCC-EPKK
EZY75JX EHAM-EGGW
EZY76CL EHAM-LKPR
LOT26E EHAM-EPWA
PBD889 ULLI-EGSS
STK2AA EHGG-EGMC
TOM548 EGBB-VOGO
Michel
Afternoon Alan,
Thanks for the Thomson/TUI information.
IBK7EM : EKCH-LEAL
BEE3AJ : LEAL-EGCN
BEE871J : LEAL-EGTE
EWG9530 : EDDL-LEAL
AFR514 : LFPG-DNAA-DNPO
VLG24TL : LEIB-LEZL
LDM52ZK : GCRR-LOWW
EZY15AL : LEZL-LFMN
CFG1LP : GCRR-EDDL
CarlosAbreu
06-11-2018 Updated file in attach.
Carlos
