0 Members and 261 Guests are viewing this topic.
#16605
That's the problem with non scheduled flights, especially one off flights like cargo charters,  its near impossible and can only usually be found with any degree of certainty if you follow them all the way to landing.  About the only persons that know where the are going to is the operator and ATC.
hf.radionorthwest
 hi alan
this is prob an re reg as it only shows hex and reg
took photo myself inb man from my home alan
* 89635D GWC5 DMAA-EGCC A6-MVD CL60 SKA International... 2018/12/20 14:05:05
#16607
That one has been in the d/b since February and all the data is there
89635D,A6-MVD,5884,Canadair CL-600-2B16 Challenger 605,SKA International Group/Gulf Wings
The 2 previous aircraft you mentioned are also in the database.  As a check, how many records are you showing in the aircraft table, todays download has 441,314 records, how many is yours showing
hf.radionorthwest
hi alan
dont know not got clue did an data base update last week i think alan
andy
If you go to File/Database Explorer/Tables/Aircraft wait a minute or so and the bottom row will give the details per attached
hf.radionorthwest
hi alan
* 040140  ETH728                   ET-AUO     B789  Ethiopian Airlines   2018/12/21 07:02:43  [**EBBR-EGCC**]
andy
Hi Andy
The aircraft itself is in the database and for info the full routing is HAAB-EBBR-EGCC
ffa1978
It decodes to N241GK which isn't allocated as the number are in a sequence I presume it is a miscode which is unknown to me
Michel
Alan,
AEE633 EGPH-LGAV
BEE48K EHAM-EGHI
DLH983 EIDW-EDDF
EXS607 EGNM-LHBP
EWG1142 EDDL-MDLR
EWG210 EDDM-MDPC
EZY2174 EDLW-EGGW
PGT1261 LTFJ-EHRD
THY6310 EHAM-LTBA
Michel
CarlosAbreu
21-12-2018 Updated file in attach.
Carlos
Cable: Ecoflex 10 (15m)
Station: XRange2 PGANRB501386
Antenna: Airnav Systems
Cable: LBC240 00220M (15m)
GreekSpy2001
424B36 c/s field shows MCLHL in to FAB just now.  Updated my db yesterday so new biz?
Graham
Evening Terry
9H-GJC is no longer it was re-registered to 9H-NYC today using the same hex code and is now with Air Charter X
