0 Members and 109 Guests are viewing this topic.
JY-PTC is also on MIDRMA as 3246 and hex 744238 but JY-PTD isn't on it.  XFW blog gives 3925 PTR JY-PTD, SHJ-AMM 15 May.
What has happened, once again I-DUNO
X
#1741
I am giving up with this, as I have said along, I believe JY-PTC has to be SU-BQK or why would JY-PTD and SU-BQK be on flights at exactly the same time...it make no sense hex wise unless there is a wrong box/ swap/coding error. JY-PTC has not been seen recently but JY-PTD landed in AMM from JED this afternoon while SU-BQK was flying from Taif to Cairo.
Without seeing them I-DUNO either
X
X
#1742
JY-PTC was eyeballed by Paul and me 28/11/15...so it does/did exist
X
#1743
Did exist, November would appear to be the common denominator of when it was last seen,  where is it and what is it now.  It may be that you are correct and all the databases, are wrong but how will we know??  MIDRAMA is not known as being infallible.
X
#1744
Easy.... two c/n 3925's cannot be flying at the same time simultaneously
X
#1745
No one is suggesting two 3925's are flying. MIDRAMA gives SU-BQK as 3925 and they are not always correct but that is the only 3925.
X
#1746
The answer
See photo from Paul of JY-PTC c/n 3246 flying 20/6/15 so is miscoding as JY-PTD! A box swop as suggested.
X
It may well be but the only way we will find out for certain is if it comes to an airport near you and we get an eyeball and have a box running.  It is probably why JY-PTD is not on MIDRAMA.
Bloody miscodes
X
because JY-PTD c/n 3925 is now SU-BQK as reported and makes sense of the whole mess!
X
JY-PTD deleted from d/b and replaced by JY-PTC miscoding.  SU-BQK is already in the d/b as 3925.  Hopefully we have got there in the end was driving me daft.
X
#1750
As it was driving me mad, now what did I pick up as 896375?
I will put that down as a wrong/crossed message!
X
X
#1752
Ha ha ha, if only things were so straight forward it would be an easy life! :)
We got there in the end!
X
diddyboy
Hi Alan
Two unknowns from Djibouti.
* 04C00D        2015/07/20 14:18:48
* A98B60        2015/07/20 17:51:01
* A98B60        2015/07/20 18:09:20
Neil
Morning Neil,
A98B60,1904,FL-714,Beech B300 King Air 350,Saudi Arabia - Air Force (Miscode hex of N714EU)
Nothing on your other one.
Many thanks
