0 Members and 66 Guests are viewing this topic.
X
Alan/ffa
This is my '9N-ALX', it is RA-06368 R66 ex AC8F7D N90815 and is in DB as such, however on other platforms as 9N-ALX!
X
Hi X
It is in the database using the correct code and the miscode
X
This bizjet landed VKO with c/s TCBYR...could not make out type
* 4B8B32        2019/04/23 15:31:20
X
Hi Ingo,
Many thanks again.  Nothing to add to your unknown one
No idea on it X.  The TC-B** in the register are mostly all balloons
Afternoon Alan,
AUA31KA : LOWL-LEZL
RYR5JT : LEAL-EDDW
AEA4731 : LEBL-LEZL
AEA5203 : LEPA-LEGR
SBI6101 : ULLI-LEAL
JAF20W : GMMW-EBCI
NOS902 : BIKF-LEAL
VOE24UJ : LEMG-LFBO
CXI9115 : EDDM-GBYD
Afternoon Ian, thanks again
https://www.radarbox24.com/data/mode-s/3F6007
the above one showed up as 60(space)+07 instead of 60+07 in ANRB software. Maybe you could check the db please.
Many thanks
Hi Ingo
As far as I can tell its in OK per attached.  I deleted the serial and added it back in and can confirm there was no space
CarlosAbreu
23-04-2019 Updated file in attach.
Carlos
Cable: Ecoflex 10 (15m)
Station: XRange2 PGANRB501386
Antenna: Airnav Systems
Cable: LBC240 00220M (15m)
Morning Alan, yesterdays unknowns:
0EBFB7  VADER11 (deliberately) miscoded german MIL I guess
3D0760  DEBAU (2x) https://www.jetphotos.com/photo/9060983
MILs:
  3E98E1  PANTER                                                         2019/04/23 18:58:18
* 3E9CED  RAGET                                                          2019/04/23 16:49:31
   3EA54C  RAPTOR                                                         2019/04/23 12:40:10
   3EA54C  RAPTOR                                                         2019/04/23 13:21:51
* 3EB9BE  EAGLE2                                                         2019/04/23 13:12:28
* 3EB9BE  SHARK                                                          2019/04/23 18:04:57
* 3EB9BE  SHARK                                                          2019/04/23 19:00:37
* 3F4476  GAF844                                                         2019/04/23 16:46:54
* 3F46DF        2019/04/23 08:33:15
* 3F4727  GAF233                                                         2019/04/23 08:07:59
   3F4EFC  POLICE1                                                        2019/04/23 11:29:19
* 3F5A37  STONE2                                                         2019/04/23 07:19:17
* 3FB1DC  THUNDR3                                                        2019/04/23 11:39:44
88815C  VJC8289 https://xfw-spotter.blogspot.com/2018/11/a321-271n-vietjet-air-d-avyn-vn-a693.html (Just in Case)
A10B06  N1665G (2x)  FAA says deregistered: https://registry.faa.gov/aircraftinquiry/NNum_Results.aspx?omni=Home-N-Number&nNumberTxt=N1665G
Regards Ingo
Morning Ingo
Can confirm the A21N, caught it this morning over India and added it in
Caught N1665G yesterday and other than the one on FAA I cant see it has ever been allocated
The others all added in
Many thanks
