0 Members and 29 Guests are viewing this topic.
Thanks for those Michel
Cheers Terry, thanks.  Unfortunately most of those will never be seen in that guise
CarlosAbreu
25-04-2019 Updated file in attach.
Carlos
Cable: Ecoflex 10 (15m)
Station: XRange2 PGANRB501386
Antenna: Airnav Systems
Cable: LBC240 00220M (15m)
noviarli
Correction :
True actual data :
Hex Code = 8A0764
Reg = PK-XDP
Aircraft Type = N219
Owner = PT Dirgantara Indonesia
Serial No. = PD2
Many thanks Noviarli, much appreciated
#17826
Morning Terry, many thanks
I have kept 2-MFIG as it is in the database with a capital N instead of the small n you detail
Good Morning Alan, yesterdays unknowns:
MILs:
  3E8085  GAF496                                                         2019/04/25 11:33:01
   3EB6F8        2019/04/25 12:58:15
   3EB6F8        2019/04/25 19:40:00
   3EB6F8  HELI115                                                        2019/04/25 21:21:40
* 3F4AD8        2019/04/25 07:49:22
* 3F5D83  GAF787                                                         2019/04/25 08:39:59
* 3F5D83  GAF787                                                         2019/04/25 10:14:21
   3F973E        2019/04/25 07:23:00
* 3F989C        2019/04/25 07:29:17
   3FA7FB        2019/04/25 12:38:45
* 3FBCEE  SLAYER1                                                        2019/04/25 14:45:44
3FF722  DMMTX (2x) no further information
4AAA86  SEJTF no further information
4AAA88  SEJTH no further information
A0AA5A  N142CK FAA has it as deregistered: https://registry.faa.gov/aircraftinquiry/NNum_Results.aspx?omni=Home-N-Number&nNumberTxt=N142CK
Regards Ingo
Good morning Ingo
Mil tac added apart  from the heli
Noting on D-MMTX
I have nothing on the 2 Swedes as they are not on the register yet but I believe they are 2 AS50's on delivery.  They will be added in when the register is updated
There have been 2 N142CK's that I can see.  One is an SR22 on the Turkish register and the other is a PA44 now N799MC so it remains unknown
Afternoon Alan,
TVF49GQ : LFPO-LEAL
AEA4775 : LEBL-LEAL
JAF24A : LEAL-EBOS
ANE89AP : LEAL-LEIB
ENT1084 : GMAD-EPWA
MAC337 : GMFF-LFMT
VLG901P : LIME-LEAL
IBK5100 : LEMG-EDDM
Evening Ian, thanks again
Evening Terry, many thanks
X
#17832
* 424481  SDM5451                                                        2019/04/26 23:14:19
* A482CE        2019/04/26 20:22:58
last one decodes to N390AE
X
CarlosAbreu
26-04-2019 Updated file in attach.
Carlos
MILs:
* 3F9AB5  STONE3                                                         2019/04/26 07:04:26
* 3F9FCC  DARK1                                                          2019/04/26 07:55:18
88816E  HVN93 https://xfw-spotter.blogspot.com/2019/01/a321-272n-vietnam-airlines-d-ayat-vn.html (just in case)
Regards Ingo
