0 Members and 52 Guests are viewing this topic.
X
MJC382 arrived in Milan MXP from Ekaterinburg SVX
X
400M23R
70A9B6 is 9N-ANF DH8D 4147 Shree Airlines
407814 is G-HMGA B200 BB-744 ACH London Ltd (Coast Guard Livery)
Graham
hf.radionorthwest
hello graham
tyvm for the info
andy
Andy
70A9B6,9N-ANF,4147,De Havilland Canada DHC-8-Q402 Dash 8,Shree Airlines, was added yesterday as it came over the UK on delivery out of Iceland
As long as it has a hex code the flight levels show, doesnt even need to be in the database
106C89 no allocation unknown to me presumably a miscode or decoding error
The registration details of all the aircraft you detail are in the database, when did you last update
X
N313DC was added to the d/b 13/8, no idea why you are not getting these updates
7816D2,B-8305,2032,Gulfstream Aerospace G280,Minsheng Financial Leasing has been identified as using 780D26 but flight plane gives the registration as B-8305 and type as G280 routed USSS-LIMC
No details on 791559
hf.radionorthwest
hi alan
i did an last update last night and again today alan i not happy with this new dongle at all will be looking for something else i am just geting to much blank info and a lot of hexcode showing so its no better then the mirco dongle alan.
andy
#18741
How many aircraft do you have in the aircraft table Andy, todays update should give around 447,859 rows.  I presume that you reinstalled the software and now have 2 instances on the computer and the update is going to the wrong instance.
I would suggest you uninstall the instance you recentkly installed and use the one you were using previously.
hf.radionorthwest
hi alan
i uninstalled the software that i use to use for the mirco and installed new software sent via email from airnav alan
andy
#18743
Its nothing to do with the dongle its the software and how you installed it.  If you use your previous dongle you will get the same results.
See the previous email, did you manually delete the orphan files left when you uninstalled. You should have the 447, 485 rows, how many do you have in yours I would suggest you have around the 200,000 that comes with the software.
They will have sent a link to the version available at the top of the page under software which is basically the same as you has except that it can also be used by the x-range receiver and there was no need for you to change from what you were using
Did you install to program files as advised or did you install to c:\Airnav
hf.radionorthwest
hi alan
i have 2569 rows 11ms
i have been useing the populate in mylog alan
andy
hf.radionorthwest
hi alan
i uninstalled the old airnav software as when i clickd on the airnav icon it would not start up so sent an email to airnav then they sent me an link to stsrt all over again but i had to uninstall the old airnav software alan.
andy
As I thought Andy
The update is going to the old database not your new download.  I believe populatein Mylog will do the same
My suggestion is to uninstall.  Once you have done that go into Windows look for a folder named Airnav and delete it, go into program files again llook for a folder named Airnav and delete it.  Use the windows search function type Airnav and if anything shows delete it.  Then install to c:\Airnav not the default program files as suggested by the Airnav software installer.  You should then be able to updated correctly
hf.radionorthwest
hi alan
i am not very good at tec stuff and i will only mess it up alan and we had to do the drivers if i start messing about with it i may lose the driver alan
andy
Can you not get someone to do it for you
AirMe
Callsign for IG1115 is ISS11GR OLB-FCO
Callsign for IG1114 is ISS11BY FCO-OLB
